Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
selveti:
February 02, 2019, 07:12:43 PM »
hi to every one i am from yougoslavia macedonia but i live in Switzerland long time i am reading here posts but its time
to answer you and ask you something very important!!! read this it is very important to everyone that is wasting time with wrong informations
and sometimes fake infos
i am in this projects for a long time with years ...i spend days and nights i even bought alot of tools alot of materials to work with it  because i enjoy doing things... but i never found 1 real answear from anybody on internet simple question now to all of those are trying to be so smart!!
and i am sure nobody can answer this accept kapanadze knows this and don smith and maby someone else because this question is the main key to overunety!!!  (HOW DO YOU CONVERT HIGH VOLTAGE HIGH FREQUENCY TO 120V 60HZ!) dear friends if someone answers to you this question with the correct diagram!!!! not with some fake answers or amateur diagrams or mixed diagrams like mos people post here and they havent self figer it out.... my answer to some idiots here is stop posting bullshit here but post here what is really helpful or better post the succeseful diagram here..
the only diagram that i was succeseful to replicate is from gerard morin transformer loop ... about the others i am still in the process and this is not something easy cause if it was easy the device will already be in public  in alot of country but this has to do also with supression it has to do with your life...... in switzerland if you replicate this you will end up in jail in eastern europe if you replicate kapanadze its highly danger to be killed cause i come from yougoslavia i know how things are runing there i speak the tesla language and ofcourse if i discover anything i can never tell that to someone because its over. dear friends there something you have to know
i never found anything that works according to some idiots diagrams .. its not that i dont believe.... .... but the only device that i believe it works
is 1 kapanadze i mean original kapanadze not fake ones and stepanov has better output and gerard morin transformers looping ...and this last one
i have replicated it works ok as it is described gerard morin my question is to some idiots here for how long you gone post every day different diagrams
of kapanadze... everyday i read posts here one says i think here has cap i think here is ground i think this i think that bla bla bla bullshit,  stop dreaming .....if you have replicated something from kapagen with succes than post it if you are serious and if you can!!,,,, dont confuse alot of people here with different fake infos .... i also followed wesley .... my opinion about wesley i think hes trying to   hide the real deal or he is just wasting your times with different infos .... i saw alot of videos from him, non of them confirm 10%  good result, wake up people study by your self .... do you think that if someone will replicate kapagen successful with post here the diagram!!!!! no way .... i dont think so but less you can do is post something that will be close to that.... and something helpful and do some more tests i see alot of people here are just reading and they post opinions without testing and building the devices my friend.... with fantasy words i can blow your mind.... but thats not gone help you, people need prove or something helpful... thats all my friends i wish to everyone success about everything. thank you
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/20430/
color
[1.1 из 4]
Потратил время, просмотрел все видео, некоторые несколько раз, что-то уже представляю для себя.
Катушки в установке. Горшок. "Шняга".
Тут катушек как минимум 5. Две у Теслы (трансформатора Теслы) - индуктор и высоковольтная ВВ на трубе, одна редкая из 6-7 больших витков - антенна (над индуктором), и еще две катушки на трубе, намотаны плотно одна поверх другой - индуктор в резонансном контуре, и съёмный бифиляр или по-другому граната.
И еще три обмотки на большом ферромагнитном тороиде-магнитопроводе, или горшке (3-4 витка для резонансного контура индуктора, 26-28 витков в контуре съёмного бифиляра-гранаты, и 12+12 витков для пушпула), это ферритовое кольцо от старого электронно-лучевого кинескопа телевизора.
И "шняга" на куске круглого ферромагнитного стержня с двумя встречно намотанными обмотками из 5-6 витков, соединяет ВВ Теслы и антенну.
Два генератора - Теслы и пушпул
Тут два независимых генератора, 1) генератор пуш-пул (или накачка), стандартная схема, пушпул Push-Pull переводится тяни-толкай (дословно толкай-тяни) 2) генератор на Теслу - это может быть управляемый качер, или скорее всего тут чаще используется второй независимый и управляемый генератор, с обратной связью от резонансного контура, куда входит катушка-индуктор. Частоты обоих генераторов точно и стабильно кратные, это очень важно.
Согласование и кратность частот двух генераторов
Пушпул работает на видео на частоте 15 кГц. Генератор Теслы работает на частоте 1,5 МГц, он выдает импульсы на катушку-индуктор Теслы (или скорее всего выдает пачки импульсов) - такие частоты называет Руслан в этом видео (он привез в лес и осциллограф, и подстраивал генератор на месте, но не снимал это). Да и во всех других роликах по данному типу генератора - частоты близкие к этим. Т.е. кратность частот в этой установке 1 к 100 видимо.
В других типах генераторов СЕ кратность частот двух внутренних генераторов может быть меньше: от 1 к 4, до 1 к 40.
Варианты согласования частот. ФАПЧ
Может быть, он использует делитель частоты генератора на Теслу (она около 1,5 МГц), и после деления 100 к 1 этой новой низкой частотой управляет работой пушпула, тут синхронизация двух частот автоматическая (в последних вариантах установки). Тогда ФАПЧ не нужен, как и говорит Руслан в последних роликах.
ФАПЧ - это фазовая автоматическая подстройка частоты (слежение и подстройка частоты и фазы между двумя сигналами), бывает еще просто АПЧ (только для частоты).
Или может быть, есть два независимых генератора, но один (на Теслу, высокочастотный ~ 1,5 МГц, на одном мосфете IRFP 460) подстраивается по частоте и по фазе, очень точно подстраивается - это важно !!!, к частоте и фазе низкочастотных колебаний тока (~ 15 кГц) в цепи индуктора, или по другому это резонансный контур (первые варианты установки, нужна ФАПЧ). А частота низкочастотных колебаний в катушке-индукторе задается частотой генератора пушпул. То есть в таком варианте генератор Теслы подстраивается по частоте (с учетом постоянной, фиксированной кратности двух частот) к генератору пушпул.
Возможно и наоборот: к частоте генератора Теслы подстраивается частота генератора пушпул (при соблюдении кратности частот 1 к 100). Потому что желательно раскачивать ВВ катушку Теслы генератором Теслы именно на собственной частоте, чтобы получить максимальные по напряжению ВВ импульсы на выходе ВВ катушки, и чтобы ВВ импульсы сохраняли свою однополярность.
Есть плюсы и минусы у обоих вариантов.?
[2 из 4]
Вследствие экспериментов, и вследствие роста понимания у самого Руслана как работает генератор (и в т.ч. из-за разных силовых полупроводников) у него в роликах несколько вариантов схем включения катушек и узлов. И вообще он собрал и довел до рабочего режима (т.е. настроил до генерации) несколько типов генераторов, т.е. схем с разными катушками.
Первичны процессы в катушках (и в колебательных контурах, в которые эти катушки входят), чтобы получить прирост энергии. А электронные компоненты, варианты схем - это важно, но все-таки вторично, это всего лишь способ добиться нужных режимов в катушках, в том числе способ получать нужные короткие высоковольтные однополярные импульсы, действующиие на заряженные частицы, колеблющиеся в резонансном контуре - от чего и возникает СЕ. Для СЕ нужно очень хорошая, т.е. точная и стабильная, синхронность (и синфазность) внешних однополярных ВВ импульсов и колебаний тока в индукторе, стабильное и точное поддержание кратности их частот. Переход в режим возбуждения СЕ очень узкий по настройкам, этот режим капризный и ко всему чувствительный, возбуждение режима СЕ очень "жёсткое". Всё это говорит Руслан.
Похоже режим СЕ может зависеть от любой мелочи, не все из которых сам Руслан осознает, понимает до конца. Или он видит их в экспериментах и при настройке, но о "мелочах" не говорит в роликах. Чтобы народ работал сам, чтобы у других появлялся свой опыт и своё понимание процессов в установке.
А вообще, с ходу на тяп-ляп настроить не получится. Все это Руслан повторял и повторяет много раз в своих роликах.
ВВ импульсы нужны однополярные, точнее как можно более однополярные. И Руслан очевидно использует не один импульс, а короткую пачку импульсов.
Чтобы добиться всего этого (синхронность, правильность длительности импульсов и пауз между ними, стабильность работы всего устройства), нужно как минимум очень тщательно фильтровать помехи в цепях питания и в цепях управления, экранировать и заземлять платы узлов, экранировать и заземлять провода управления и силовые (сильноточные) провода рядом с платами, стабилизировать максимально все питания по напряжению. Нужно тщательно выполнять монтаж элементов на платах, использовать короткие проводники, нужно хорошо закреплять все катушки, провода от них, контурные конденсаторы (чтобы просто частота не плавала, тут нужна стабильность в единицы кГц, если не в сотни, десятки и даже единицы герц). Естественно везде надо использовать хорошие элементы, с запасами по характеристикам. Об этом тоже постоянно говорит Руслан в роликах.
Ему жалуются, что у других не получается. А он отвечает в том смысле, что в конечном счете вы сами виноваты, и что вы просто не хотите понять и разобраться самостоятельно в процессах, исследовать, что происходит в генераторе, в катушках. Что он хотел и мог - он все рассказал. Действительно, Руслан и так рассказал очень много, по сравнению с другими авторами работающих генераторов СЕ.
Видимо он сам привык все делать аккуратно и последовательно, привык много работать, и для него несколько дико, что очень многие делают все по-другому, делают небрежно, и главное бездумно. Не слушают, что он говорит, порют отсебятину (у многих повторяльщиков свой собственный большой опыт, отсюда излишняя самоуверенность), а потом жалуются, что не получается.
Короче, такая примерно картинка сложилась для меня на текущий момент, из просмотра практически всех роликов, и многих схем.?
[3.1 из 4]
После просмотра роликов и упорядочивания инфы - сложилась такая схема циркуляции энергии.
От источника питания (сначала аккумулятор, затем в самозапите стандартный инвертор 220-240 В / 24 В, у которого вся крышка в небольших отверстиях-дырках) запитывается генератор по схеме пушпул, он достаточно мощный, при питании 24 В токи на тестовых лампах-нагрузках более 20 А.
От источника питания через два ключа-мосфета пушпул по очереди выдает прямоугольные однополярные импульсы тока на два плеча (две половины обмотки, 12 и 12 витков если питание 24 В, с общей средней точкой), направление тока в плечах противоположное (встречное, по очереди сначала слева к середине, затем справа к середине, и т.д.), направление обмотки одинаковое в обоих половинах-плечах, из середины просто сделан отвод. Из-за встречности токов в плечах магнитный поток вдоль горшка полпериода направлен в одну сторону, полпериода в противоположную сторону. В итоге на горшок и другие обмотки на нём как бы действуют двуполярные импульсы тока, с размахом напряжения на ключах, равным плюс-минус напряжению питания.
Между прямоугольными управляющими импульсами напряжения от микросхемы TL494, значит между импульсами на драйверы мосфетов, значит между плюс-минус импульсами тока через ключи-мосфеты, от пушпула на плечи - есть паузы. Это мертвое время пушпула, тут часть времени занимают нарастающие и спадающие фронты прямоугольных импульсов. В итоге получается какое-то двуполярное прямоугольное приближение к двуполярной гладкой синусоиде.
Паузы в пушпуле - это защита ключей от перегрузок по току т.е. от короткого замыкания. Токи в одинаковых плечах встречные и равные, поэтому если будут открыты оба ключа одновременно, то будет два встречных и равных магнитных потока, они скомпенсируются, индуктивное сопротивление станет практически ноль, останется только ничтожное омическое сопротивление толстого провода в плечах (по 12 витков), т.е. на ключах будет КЗ - если нет защитных пауз между импульсами.
Через ферритовый горшок прямоугольные двуполярные импульсы тока (колебания) от пушпула передаются одновременно и в съёмный контур (там катушка граната-бифиляр, один а скорее два конденсатора, всё на заземлении), и в резонансный контур (там катушка индуктор, конденсатор, и тоже всё на заземлении; есть еще бесконтактный датчик тока для обратной связи).
Под действием этих импульсов тока от пушпула в обоих контурах возникают вынужденные колебания электрического тока.
Одновременно от источника питания работает управляемый генератор на катушку-индуктор Теслы. Генератор выдает точные импульсы тока в индуктор Теслы, они возбуждают импульсы тока и напряжения в высоковольтной вторичной ВВ катушке Теслы. Напряжение импульса во вторичной ВВ катушке возрастает с расстоянием (числом витков) от индуктора Теслы, на конце ВВ оно порядка нескольких киловольт (2-5 кВ). Другой конец ВВ, который близко к индуктору Теслы, присоединен к заземлению.
Этот высоковольтные импульсы с конца ВВ, через фильтр-регулятор "шнягу", поступают на внешнюю редкую катушку-антенну, на один её конец, второй конец ни с чем не связан (висит в воздухе).
"Шняга" видимо немного задерживает прохождение ВВ импульса, и гасит колебания малой амплитуды около нуля (немного рассеивает энергию). Причем эти свойства могут несильно регулироваться: числом витков, и расстоянием между витками и между встречными обмотками, положением, размерами и материалом (свойствами) ферритового сердечника, другими параметрами. Это один из узлов тонкой настройки.
Антенна находится поверх индуктора, ниже под этой катушкой находится граната-бифиляр. И в индукторе, и в гранате-бифиляре текут переменные токи, т.е. двигаются заряженные частицы. На частицы действуют однополярные ВВ импульсы напряжения в антенне. Но индуктор находятся прямо под антенной, внутри антенны, ближе всего к антенне. А граната находится (намотана) под индуктором, тоже внутри антенны но частично экранирована от антенны индуктором. Поэтому однополярные ВВ импульсы напряжения в антенне действуют в основном на ток, на частицы в индукторе, т.е. на резонансный контур. А не на гранату-бифиляр, т.е. на съёмный контур.
В резонансном контуре нет гальванического съёма энергии, нет нагрузки. Нагрузка и гальванический съём энергии происходят в съёмном контуре.
Резонансный контур раскачивается двуполярными прямоугольными импульсами тока от пушпула, через горшок и обмотку 3-4 витка (так же как и съёмный контур, через горшок и обмотку 26-28 витков). Поэтому в ненагруженном резонансном контуре, куда включен индуктор, возникают вынужденные колебания. Эти колебания настраиваются также подбором ёмкости контурного конденсатора, возможно до совпадения (или максимально близкого приближения) возбуждающей частоты от пушпула - с частотой собственных колебаний тока и напряжения в резонансном контуре, следовательно до максимальной амлитуды колебаний - т.е. до резонанса.
Так как, кроме приближения частоты собственных колебаний контура (путем подбора ёмкости контурного конденсатора) к вынуждающей частоте от пушпула (~ 15 кГц, а она в свою очередь должна быть точно и стабильно привязана к собственной частоте ВВ катушки Теслы ~ 1,5 МГц, с постоянной кратностью по частотам 100 к 1), на резонансный контур также сильно действуют внешние однополярные ВВ импульсов от Теслы - то амплитуда колебаний тока в резонансном контуре доходит до 100 ампер. Кулабухов измерял ток, и сообщает в одном из видео.
Для измерения тока, и для схемы ФАПЧ используется датчик - трансформатор тока. Это небольшое ферритовое кольцо с обмоткой, концы обмотки присоединены к достаточно мощному резистору, несколько килоом. Кольцо надето на провод резонансного контура, по которому текут измеряемые значительные и большие токи. Измеряется величина и форма напряжения на обмотке кольца (т.е. на сопротивлении) - осциллографом, или схемой ФАПЧ.
Ферритовый материал кольца может входить в состояние насыщения при максимальном значении тока в проводе (значит и в обмотке кольца), при этом форма импульса напряжения на обмотке становится острой. Видимо для синхронизации по фазе и частоте (для ФАПЧ) желателен импульс с острой формой, т.е. переход в насыщение феррита по напряженности магнитного поля, т.е. нужно небольшое поперечное сечение кольца и много витков. Для измерения тока - насыщение не нужно, поэтому число витков небольшое, а само кольцо побольше. Естественно влияет магнитная проницаемость феррита. Количество витков на этом кольце в роликах разное, Руслан упоминал и о 100 витках, и о 30 витках. В последних роликах количество витков небольшое, порядка 20-30.?
[4 из 4]
Чтобы получить добавку энергии (СЕ) нужно каким-то хитрым, пока непонятным до конца способом синхронизировать колебания большого тока в индукторе (резонансном LC-контуре) и высоковольтные импульсы напряжения на антенне (или недлинную пачку этих ВВ импульсов). Т.е. синхронизировать синусоидальные токи в LC-контуре-индукторе - с однополярными импульсами тока в индукторе Теслы, которые создают ВВ импульсы напряжения на антенне.
Если всё сделано правильно, всё согласовано и настроено правильно - импульсы напряжения от Теслы как бы толкают заряженные частицы в индукторе, возникает прирост энергии, появляется Свободная Энергия (СЕ). Это показывают результаты Руслана Кулабухова. Об этих выводах он говорит прямо, четко, и не один раз в своих роликах.
Понятно, что практика получения СЕ есть не только у Кулабухова. СЕ получают например Роман Карноухов (Акула), Александр Романов, Сергей Алексеев, многие другие люди.
Когда Руслан объясняет своё понимание, как получается СЕ, он говорит также, что заряженные частицы не только двигаются, но и вращаются, причем синхронно, согласованно, отсюда и получаются синусоидальные колебания.
Такое описание внешне чем-то сильно напоминает теорию Александра Романова (которую хорошо понимает только один Романов, видимо, к сожалению).
А именно, по Романову: заряженные частицы могут стоять (т.е. не двигаться по проводнику) и при этом они могут синхронно вращаться вокруг своих осей сильнее-слабее, и могут синхронно изменять направления осей вращения. В результате по проводнику может передаваться энергия без движения заряженных частиц. (Конечно частицы могут также двигаться поступательно и этим передавать энергию - как в обычном электрическом токе).
Романов говорит также - для получения СЕ надо складывать ток и напряжение (видимо подразумевается большой ток и высокое напряжение).
Далее (после толкания частиц в индукторе импульсами от Теслы) часть энергии снимается, но не из резонансного, а из съёмного LC-контура (в него входит бифилярная катушка-граната).
Это делается подключением (т.е. гальванически) силового выпрямительного моста на четырёх ВЧ диодах к конденсатору в контуре, т.е. за счет выпрямления части переменного тока из съёмного контура (с выпрямлением всего напряжения в контуре на конденсаторе) .
После диодного моста стоит накопительный и сглаживающий конденсатор. У Кулабухова в одной из версий генератора показано, что это неполярный конденсатор (или 10 мкФ 630 В, или 12 мкФ 450 В).
Далее выпрямленное и сглаженное напряжение (и ток), после диодного моста и накопительно-сглаживающего конденсатора (то есть выведенная из съёмного LC-контура часть энергии):
1) частично возвращается в стандартный инвертор (блок питания) 220/24 В, там преобразуется вниз по напряжению (постоянное напряжение понижается от приблизительно 220 вольт DC до стабилизированных 24 вольт DC), и далее идет на самозапит установки,
2) частично выводится из установки в полезную нагрузку (через розетку с выключателем), например на лампы по 500 ватт.
В съёмный LC-контур похоже может входить не один, а два конденсатора C.
Например в одном ролике показан вариант включения одного конденсатора C1 параллельно малой катушке-обмотке на горшке L1, второй конденсатор C2 включен последовательно с большой катушкой-гранатой L2 и обмоткой L1 .
То есть в съёмный контур входят две катушки: обмотка 26-28 витков на ферритовом горшке (L1), и катушка граната-бифиляр (L2) с определенной общей длиной провода 38 м и неопределенным числом витков.
Всего может быть до 4 разных вариантов включения 2 катушек и 2 конденсаторов в один замкнутый контур.
В одном ролике показан один конкретный вариант съёмного контура, описаный выше (C1 параллельно L1, C2 последовательно с L2 и L1).
В другом ролике показано включение всех 4 элементов (C1 L1 C2 L2) последовательно.
В более позднем ролике Руслан дает еще один вариант съёмного контура, в который входят катушка-граната, обмотка 26-28 витков на горшке, и один конденсатор (не два), заземленный с одной стороны - они включены последовательно. Плюс дополнительно катушка-сглаживающий дроссель, который включен между конденсатором (незаземленный вывод) и одим входом выпрямительного диодного моста, второй вход моста соединен с заземленным выводом конденсатора.
Во второй, резонансный LC_контур входят две катушки: катушка-индуктор, и обмотка 3-4 витка на горшке, и входит один конденсатор. Они соединены последовательно.
Ёмкость конденсатора обязательно настраивается, похоже, т.к. он составлен из нескольких параллельных конденсаторов.
Во всех видео о генераторе СЕ (по мотивам генератора Акулы) - Кулабухов рекомендует считать не число витков в индукторе и в гранате-бифиляре, а общую длину провода в намотке катушек. А именно, в гранате-бифиляре должно быть 38 м (четверть длины волны с частотой около 1,8 МГц, эта частота рекомендована Карноуховым из его опытов). В индукторе длина провода должна быть ровно в 2 раза меньше чем в гранате, т.е. 19 м.
Обе катушки наматываются на стандартную пластмассовую трубу 50 мм, некоторыми усложненными способами (описано в деталях), про это Руслан говорил несколько раз.
Сечение провода в катушках в самых первых роликах было 2,5 мм2 (возможно даже 1,5 мм2), в последних роликах может быть и больше (4 мм2), из-за роста токов и мощности установки.
В самых последних роликов Руслан говорит, что намотка бифиляром в съёмной гранате не обязательна, и даже может быть вредна.
Циркуляция энергии
Что интересно по съёмному LC-контуру.
Получается, что в него одновременно вкачивается энергия от внутреннего блока питания (БП) - на питание пушпула и его 2-х полуобмоток (плечи) через 2 ключа, далее через магнитопровод-горшок и обмотку 26-28 витков энергия вводится в съёмный LC-контур.
Одновременно из съёмного LC-контура часть энергии выводится, через диодный мост на контурном конденсаторе съёмного LC-контура, и далее по схеме на блок питания и параллельно на нагрузку.
Имеется циркуляция энергии по замкнутому пути (контуру):
БП => импульсы тока через ключи пушпула => плечи пушпула на горшке => электромагнитное поле по горшку => обмотка 26-28 витков на горшке => катушка-граната и съёмный контур => диодный мост => БП.
Из-за плотной, близкой намотки 2 катушек, на катушку граната-бифиляр (съёмный контур) действуют большие токи (90-100 А), протекающие через катушку-индуктор в резонансном LC-контуре. Очевидно часть энергии из этого резонансного LC-контура через электромагнитное поле передается в съёмный LC-контур.
Имеется циркуляция энергии по замкнутому пути (контуру, ветви):
БП => импульсы тока через ключи пушпула => плечи пушпула на горшке => электромагнитное поле по горшку => обмотка 3-4 витка на горшке => катушка-индуктор и резонансный контур => электромагнитное поле катушки-индуктора => катушка-граната и съёмный контур => диодный мост => БП.
К энергии колебаний тока в резонансном LC-контуре - добавляется какая-то часть энергии импульсов высокого напряжения на горячем конце ВВ катушки трансформатора Теслы, через шнягу и антенну.
БП => импульсы тока через ключ Теслы => индуктор Теслы => электромагнитное поле индуктора Теслы => ВВ Теслы => шняга => антенна => магнитная и электрическая энергия ВВ импульсов напряжения на антенне => катушка-индуктор и резонансный контур => электромагнитное поле катушки-индуктора => катушка-граната и съёмный контур => диодный мост => БП.
Можно описать схему движения энергии в установке также так.
Один общий источник-преобразователь питания дает энергию для работы двум генераторам - генератор Теслы и генератор пушпул. (Энергия от источника делится на 2 потока)
Пушпул накачивает энергией два LC-контура - резонансный и съёмный, причем эти контуры постоянно взаимодействуют и передают энергию между собой (конкретно она передается из резонансного в съёмный контур). (Энергия от пушпула делится на 2 потока)
Генератор Теслы накачивает энергией колебания в ВВ катушке (и далее через шнягу накачивает ВВ колебания на антенне). Антенна передает энергию этих ВВ колебаний в резонансный LC-контур ("импульсы Теслы толкают ток в индукторе" - говорит Кулабухов).
То есть колебания тока в резонансном контуре - накачиваются одновременно 2 источниками: генератором пушпул прямо, и генератором Теслы как бы не прямо, а через высоковольные импульсы напряжения в ВВ-катушке и антенне. (В резонансном контуре два потока энергии объединяются в один.)
Тажке и колебания тока в съёмном контуре - накачиваются одновременно 2 источниками: генератором пушпул прямо, и колебаниями большого тока в близко намотанном резонансном контуре. (В съёмном контуре два потока энергии объединяются в один.)
Часть энергии колебаний тока в съёмном контуре - выводится через контурный конденсатор и диодный мост (т.е. выводится-снимается не вся энергия колебаний в съёмном контуре). (Поток энергии в съёмном контуре делится на два потока, один поток по-прежнему колеблется-циркулирует внутри контура, второй поток выводится из контура.)
Эта выведенная-снятая энергия разделяется на 2 параллельных потока. Частично она возвращается в общий для всех узлов устройства источник-преобразователь питания (БП), чтобы после преобразования в БП замкнуть циркуляцию энергии по замкнутому кругу внутри установки (самозапит).
Оставшаяся часть снятой энергии - выводится на полезную внешнюю нагрузку.
Вот такие интересные 3 контура (замкнутые пути) циркуляции энергии вырисовываются.?
[1.2 из 4]
Два независимых генератора. Случай уплывания высокой частоты, и кратности частот
В данной установке частота генератора Теслы приблизительно в 100 раз больше частоты генератора пушпул (примерно 1,5 МГц и 15 кГц). Поэтому изменение (уплывание) частоты Теслы скажем на 0,1% (относительные единицы), или на 1,5 кГц в абсолютных единицах - соответствует для пуш-пула в 100 раз большему относительному изменению частоты. Например, изменение частоты Теслы (исходно 1500 кГц) на абсолютные 1,5 кГц - относительно высокой частоты Теслы это 0,1%, относительно низкой частоты пуш-пула (15 кГц) это 10% (1,5 и 15 кГц).
Соотношение уплывания частот на 0,1% и на 10% (1 : 100), относительно собственных частот двух систем, при изменении высокой собственной частоты - справедливо, если две колеблющиеся системы (ВВ+шняга+антенна, и резонансный LC-контур) - независимы (могут независимо менять свои собственные частоты), и два генератора, накачивающие энергией каждый свою систему - работают независимо друг от друга. Причем оба генератора (пушпула и Теслы) независимо друг от друга могут накачивать свои системы энергией на собственной (резонансной) частоте этих систем, т.е. оптимально.
Один генератор независимый, другой зависит от него
Частоту накачки пуш-пулом можно жестко привязать к частоте генератора Теслы, за счет деления частоты генератора Теслы в нужное фиксированное число раз (например в 100 раз). То есть из двух независимых генераторов - оставить только один генератор (Тесла) независимым, а второй генератор (пуш-пул) привязать по частоте (и по фазе) к первому генератору.
Можно заранее настроить в резонанс, подбором ёмкости конденсаторов, те LC-контуры, которые настроены на вынуждающую частоту пушпула (с большой вероятностью это резонансный LC-контур индуктор, и возможно настроен в резонанс и съёмный LC-контур).
BROKEN INTO TWO PARTS DUE TO CHAR OVERFLOW
ADMIN
color
Частота генератора на индуктор Теслы может меняться, уплывать от начального значения, допустим совсем незначительно - на 0,1%, или 1,5 кГц.
Например, если генератор Теслы сам по себе недостаточно стабилизирован, и не имеет обратной связи с системой катушек, которые он накачивает (что происходит с собственной частотой системы из 3 катушек - в этом случае неважно). Или если генератор Теслы автоматически подстраивается к этой собственной частоте (обратная связь есть), а собственная частота системы катушек "ВВ Теслы+шняга+антенна" по каким-то причинам изменилась (пусть на те же 0,1%).
Тогда частота генератора пушпул тоже изменится, из-за её жесткой привязки к частоте генератора Теслы.
Допустим на Тесле была частота 1500 кГц, и стала частота 1501,5 кГц (частота Теслы уплыла на 0,1% или на 1,5 кГц). После деления частоты ровно в 100 раз, на пуш-пуле была частота 15 кГц, стала 15,015 кГц, то есть относительно исходных 15 кГц частота пуш-пула тоже увеличилась на 0,1% или на 0,015 кГц.
Еще раз.
Без деления частоты. Допустим вначале было 1500 кГц и 15 кГц, кратность частот ровно 100,00=1500/15. Стало 1501,5 кГц и те же 15 кГц, кратность частот 1501,5/15 = 100,1.
С делением частоты. Вначале были 1500 кГц и 15 кГц и кратность 100,00. Стало 1501,5 кГц и 15,015 кГц, кратность из-за деления сохранилась 100,00.
Но сохранилась ценой увеличения частоты пушпула на те же 0,1%, за счет ненужного ухода пушпула от собственной (резонансной) частоты его системы (резонансного LC-контура), без необходимости для этого (считаем что собственная частота системы пушпула не изменилась).
Кратность частот сохряняется. Но происходит ненужный уход частоты генератора пушпула - при уходе частоты генератора Теслы.
К чему подстраивается генератор Теслы
Генератор на ВВ Теслы должен автоматически подстраиваться к собственной частоте системы "ВВ катушка+шняга+антенна", при любых её изменениях в геометрии и в окружающем пространстве. То есть должна быть обратная связь по собственной частоте.
Согласование по частоте автоматически происходит в качере. Причем фактически без какого-либо регулирования сдвига фазы (между током в индукторе Теслы, и напряжением на выходе ВВ катушки) - если в схеме соединения холодного конца ВВ к базе транзистора нет никаких регулирующих элементов.
Обязательно должно быть точное и стабильное регулирование длительности однополярного импульса тока через индуктор Теслы (т.е. регулирование duty cycle, коэффициента заполнения), для получения максимально возможной однополярности импульса напряжения на выходе ВВ катушки Теслы. Импульс напряжения на выходе ВВ получается в ответ на импульс тока через индуктор Теслы. Смотри watch?v=VGuw3QvoseI.
К чему подстраивается генератор пушпул
Генератор пушпул с одной стороны должен быть точно кратен по частоте и фазе с генератором Теслы - для получения СЕ. С другой стороны пушпул должен быть точно настроен на собственную частоту резонансного LC-контура, куда входят катушка-индуктор и подобранный (настроенный) конденсатор контура - для раскачки максимального тока и напряжения в контуре (для получения резонанса), следовательно для увеличения СЕ.
Вариант согласования генераторов с делением частоты и подстройкой кратности деления
Собственная частота Теслы (ВВ Тесла+шняга+антенна), и собственная частота резонансного контура могут изменяться, уходить от частот при начальной настройке генераторов, причем эти 2 ухода частоты происходят независимо.
Если происходит деление частоты генератора Теслы, то кратность частот и синфазность генератора пушпул по отношению к генератору Теслы выполняется автоматически. Можно регулировать сдвиг фаз, если это имеет значение для СЕ. (Точное положение начала длинного периода низкочастотного колебания, внутри какого-то одного короткого периода высокочастотных колебаний, в серии одинаковых ВЧ колебаний в течение одного периода НЧ колебания.)
Если коэффициент деления частоты может автоматически изменяться (в небольших пределах, например с шагом 1 или 2), для сохранения частоты пушпула максимально близкой к собственной частоте резонансного контура, то одновременно подстраиваются два генератора к двум собственным частотам двух независимых резонансных систем. Для генератора Теслы точно, для генератора пушпул приближенно.
Видимо, попадание генератором в собственную частоту "ВВ Теслы +шняга +антенна" важнее для получения СЕ.
Собственная частота ВВ катушки
Собственная частота ВВ катушки трансформатора Теслы определяется параметрами ВВ катушки:
1) диаметр провода
2) диаметр каркаса
3) число витков т.е. высота намотки ВВ катушки
4) шаг намотки провода на каркасе (зазор между витками).
Т.е. во многом собственная частота ВВ катушки определяется общей длиной провода обмотки. Чем меньше общая длина провода, тем выше собственная частота катушки, и наоборот.
Влияет диаметр намотки - чем он больше, тем общая индуктивность больше, а собственная частота меньше.
Считаем, что катушка ВВ намотана в один слой в одну сторону на цилиндрическом каркасе. Каркас - пластмассовая труба с внешним диаметром 50 мм.
Распределенная ёмкость и индуктивность, полная индуктивность
Распределенная и полная индуктивность (и распределенная ёмкость) увеличивается, а собственная частота катушки уменьшается при: 1) увеличение диаметра каркаса 2) увеличении числа витков, т.е. высоты намотки 3) уменьшении диаметра провода, это произойдет собственно вследствие увеличения количества витков при той же высоте намотки.
Провод ВВ катушки можно наматывать не вплотную виток к витку, а с постоянным зазором (например двумя одинаковыми или разными проводами, затем второй провод удаляется). Для увеличения рабочего напряжения между витками, для увеличения распределенной ёмкости, и для снижения распределенной и полной индуктивности. То есть для увеличении собственной частоты катушки.
В случае намотки провода с зазором - собственная частота катушки будет зависеть от величины зазора, естественно.
Собственная частота ВВ катушки плюс другие элементы
Так как ВВ катушка через"шнягу" присоединена к катушке-антенне, то к её распределенной индуктивности и ёмкости добавляются такие же распределенные индуктивности и ёмкости "шняги" и антенны. В результате распределенная ёмкость и индуктивность всей системы становится больше, а собственная частота системы "ВВ катушка + шняга + антенна" становится заметно меньше.
Что и показано Русланом в одном из роликов, когда в качестве генератора Теслы используется схема качера.
Качер в трансформаторе Теслы
Как известно, качер на двух катушках трансформатора Теслы автоматически подстраивается именно к собственной частоте ВВ катушки (не к собственной частоте индуктора Теслы), которая находится в цепи базы, и управляет работой биполярного транзистора (индуктор находится в силовой цепи коллектора).
В ВВ катушке возникают мощные колебания тока и напряжения на её собственной частоте. На этой собственной частоте ВВ катушки - транзистор в качере выдает однополярные импульсы тока, через эмиттер-коллектор на коллекторную катушку (на индуктор Теслы), причем согласовано по фазе. Этими импульсами тока через индуктор - колебания в ВВ катушке и поддерживаются (ввод энергии от источника питания), причем именно на собственной частоте базовой катушки качера, т.е. ВВ катушки Теслы.
Качер вообще
Но в приницпе возможна работа качера и на собственной частоте коллекторной (силовой) катушки, если в ней будут достаточно сильные колебания (например она включена в LC-контур), а базовая (управляющая) катушка качера в таком режиме просто выполняет роль обратной связи. В таком случае качер будет автоматически подстраивать силовые импульсы тока через коллектор к этой собственной частоте катушки в коллекторной цепи (через обратную связь на базовой, управляющей катушке), то есть будет добавлять энергию в коллекторную катушку (LC-контур), для компенсации потерь энергии в ней.
В любом случае силовые импульсы тока через эмиттер-коллектор биполярного транзистора будут однополярными (np-переходы транзистора проводят большой ток только в одну сторону), и от плюса к минусу питания.?
[3.2 из 4]
Видимо, предположительно - важно, чтобы форма тока в резонансном контуре была максимально близкой к синусоиде. Несмотря на прямоугольную форму вынуждающих импульсов от пушпула (что ухудшает синусоидальность). С учетом сравнительно небольшой эдс, наводимой пушпулом через ферритовый сердечник горшка в обмотке 3-4 витка на горшке.
То есть сравнительно небольшая энергия, передаваемая пушпулом в контур на раскачку - не сильно ухудшает синусоидальность колебаний LC-контура.
В схемах других генераторов Кулабухова резонансный контур не раскачивается напрямую от пушпула через небольшую дополнительную обмотку (3-4 витка), как это показано в вариантах схем, в роликах по данному генератору, вроде бы.
По озвученным представлениям Романова, при колебаниях на собственной частоте (резонансе) одновременно вращающиеся и движущиеся в проводнике заряженные частицы имеют наилучшим образом, максимально согласованные направления осей вращения (направления перемещения всегда согласованы в электрическом токе), и согласованные скорости вращения и перемещения - именно в режиме свободных резонансных колебаний в LC-контуре. Предположительно.
Возможно, вследствие этой сильной согласованности - внешние высоковольтные импульсы напряжения могут добавлять свою энергию движущимся заряженным частицам, причем непропорционально больше по сравнению с энергией самих ВВ импульсов. Точнее непропорционально больше по сравнению с энергией однополярных импульсов тока в индукторе Теслы - причиной возникновения ВВ импульсов напряжения.
Эти однополярные импульсы тока в идукторе Теслы получают энергию от источника питания через ключ генератора Теслы (он замыкается-размыкается). Импульсы тока в индукторе Теслы создают переменное электромагнитное поле вокруг ВВ катушки, поле возбуждает колебания тока и напряжения в ВВ.
Размах синусоидальных колебаний напряжения вдоль ВВ растет к горячему концу, размах колебаний тока уменьшается. На горячем конце ВВ ток мал, но все-таки ток есть, т.к. проводник, куда можно течь этому небольшому переменному току - имеется, это шняга и антенна. Небольшой ток протекает через шнягу и антенну, ток равен нулю только на висящем конце антенны (обрыв провода).
На горячем конце ВВ размах двуполярных синусоидальных колебаний напряжения максимально велик (ток минимален).
Далее эти импульсы высокого напряжения идут через шнягу (2 встречно намотанные катушки с малым количеством витков, на ферритовом сердечнике диаметром возможно ~8 мм, по сути это встречный и разнесенный в пространстве бифиляр, после настройки в большинстве случаев несимметричный по числу витков). Тут они сдвигаются на какой-то угол по фазе (возможно задерживаются из-за наличия феррита).
Далее напряжение импульсов появляется (действует) на антенне, которая работает в том числе и как одна из двух, внешняя обкладка цилиндрического конденсатора (весьма редкая, не сплошная). Другая, внутренняя обкладка цилиндрического конденсатора - провод катушки-индуктора (в основном), т.к. он ближе всего к антенне.
Этот конденсатор циклически перезаряжается переменным высоковольтным напряжением с горячего конца ВВ, поэтому внутри конденсатора есть переменное электромагнитное поле и соответственно потоки энергии между обкладками.
Видимо небольшой переменный ток в антенне тоже создает своё поле и потоки энергии.
Энергия этих двуполярных высоковольтных импульсов напряжения на антенне способна увеличивать ток в катушке-индукторе, видимо, и значит увеличивать энергию колебаний в резонансном контуре. Причем увеличивать энергию колебаний тока в резонансном контуре непропорционально больше, сильнее, по сравнению с энергией импульсов тока в индукторе Теслы, идущей на раскачку трансформатора Теслы. По непонятному пока механизу. Предположительно.
На осциллограммах напряжения на горячем конце ВВ (щуп осциллографа висит в воздухе недалеко от ВВ), которые показывает Кулабухов в роликах - видно, что размах (амплитуда) колебаний высоковольтного напряжения на ВВ, после включения генератора Теслы (подачи импульсов тока на индуктор Теслы) -  устанавливается на высоком постоянном уровне не сразу . А только после приблизительно 5-7 синусоидальных колебаний высокого напряжения на ВВ Теслы, растущих по размаху. Амплитуда колебаний на ВВ быстро возрастает от какого-то начального (небольшого) уровня до постоянного, значительно более высокого уровня, в течение этих первых 5-7 колебаний напряжения на ВВ, после включения генератора Теслы.
Это видно на осциллографе в нескольких роликах Руслана (и конечно не только у него).
Видимо, в ходе этой раскачки высоковольтных колебаний на ВВ Теслы (до 5-6 киловольт, слова Кулабухова, приблизительно за 5-7 колебаний - см осциллограммы), после включения импульсов тока на индуктор Теслы - происходит постепенное (и быстрое) раскачивание среды (эфира), вокруг ВВ Теслы. До установления динамического равновесия на определенном уровне.
Возможно именно большая скорость изменения напряжения (от -5 кВ до +5 кВ, за полпериода колебаний Теслы) вызывает это сильное, заметное взаимодействие ВВ катушки с окружающей средой.
Считаем: пусть частота Теслы 1,5 МГц = 1,5*10^6 колебаний за 1 секунду, тогда длительность одного периода колебаний T=1/(1,5*10^6)=0,667*10^-6 секунды, а половина периода = 0,333*10^-6 секунды=delta t.
За полпериода колебаний напряжение на горячем конце ВВ менятеся пусть от -5*10^3 вольт до +5*10^3 вольт, или на 10^4 вольт=delta U.
Тогда скорость изменения напряжения во времени здесь можно оценить как delta U/delta t=10^4 вольт/0,333*10^-6 секунды=3*10^10 вольт в секунду (30 миллиардов вольт за 1 секунду). (10^x - означает десять в степени x)
Это весьма большая скорость нарастания и спадания переменного напряжения, в данном месте пространства и среды. Возможно поэтому ВВ Теслы на горячем конце вполне может заметно влиять на среду вокруг, сильно взаимодействовать с ней (как бы более значительно подталкивать-захватывать среду, вместе с колебательными движениями электронов по проводу ВВ). Высоковольтными быстрыми колебаниями напряжения на горячем конце ВВ - можно раскачивать некие невидимые колебания в среде, похоже.
И возможно за счет этих колебаний в среде (рядом с горячим концом ВВ, и рядом с антенной и шнягой) - можно получать какую-то дополнительную, сверхединичную энергию от этих колебаний среды, колебаний её элементов.
Понятно, что высокое напряжение само по себе сильнее поляризует среду, чем низкое напряжение (сильнее смещает от равновесия элементы среды, как бы создает бОльшее внутреннее напряжение в среде - в данном месте). При быстрой (энергичной) раскачке среды высоким переменным напряжением - среда переходит в вынужденные колебания с той же частотой, что и источник возмущений среды, и с амплитудой колебаний, падающей с удалением от источника по какому-то закону.
Возможно, что суммарная энергия этих колебаний элементов среды (затухающих при удалении от источника) такова, что в итоге можно снять из колебаний бесконечной среды энергии как бы больше, чем в сумме затратить энергии на колебания малого источника возмущений. Если делать всё правильно, если правильно (например в некоем резонансе, в некотором режиме, неким видом энергии) и возмущать среду, и снимать энергию колебаний среды (например в другом виде энергии). Всё это предположительно, естественно.
Трансформатор Теслы (точнее его ВВ катушка) раскачивается в резонансном режиме, то есть вынуждающая частота (импульсы тока через индуктор и ключ Теслы) равна частоте собственных колебаний тока и напряжения в ВВ катушке Теслы, заземленной с одного конца, и имеющей другой конец висящим в воздухе (точнее уже антенна, а не ВВ, имеет висящий в воздухе, ни с чем не соединенный конец провода).
То есть в ВВ Теслы возникает стоячая волна, которая как раз имеет свою собственную частоту колебаний (частоту волнового резонанса). На этой частоте амплитуда колебаний в стоячей волне на ВВ максимальна, что видно экспериментально при подаче возбуждения на ВВ от генератора качающейся (переменной) частоты (лучше синус), и измерения-слежения за зависимостью амплитуды на ВВ от частоты генератора.
Схема качера например легко и быстро подстраивает вынуждающую частоту импульсов тока в индукторе к этой частоте.
Стоячая волна - это результат сложения падающих и отраженных волн, имеющих одну общую частоту и постоянный сдвиг фазы между собой. Падающие волны тока и напряжения порождаются однополярными импульсами тока в индукторе Теслы, и видимо идут из участка (зоны) ВВ под индуктором к горячему концу Теслы. Отраженные волны тока и напряжения получаются из падающих волн, из-за отражения волн тока (значит и волн напряжения, взаимосвязанных с волнами тока) от горячего (висящего, разомкнутого) конца антенны (или ВВ, если антенны нет).
В генераторе разреженная, редкая катушка-индуктор Теслы находится не посередине ВВ, а на краю ВВ катушки, причем на заземленном краю.
Видимо, если говорить точнее, однополярный импульс тока в индукторе Теслы порождает импульс тока в зоне (участке) ВВ под индуктором, который мог бы разойтись в обе стороны. Но с одной стороны ВВ заземлена, и часть токового импульса в ВВ уходит через кабель заземление на землю. О чем говорит и Кулабухов. (Земля - это очень-очень большая ёмкость, имеющая поэтому постоянный потенциал, с которой кабель заземления соединен через заметное омическое сопротивление грунта вокруг заземления).
Другая часть токового импульса в ВВ идет от холодного к горячему концу ВВ, и далее всё как описано. Предположительно.
Кроме искажений синусоиды тока в резонансном контуре, из-за прямоугольной формы импульсов от пушпула, форму колебаний тока (и напряжения) искажают также короткие высоковольтные двуполярные импульсы напряжения от ВВ Теслы, которые приходят в антенну через шнягу. То есть идеальная синусоида тока и напряжения в этом LC-контуре не будет получаться, а возможно это и не нужно. Потому что независимо от степени искажения синусоиды тока в контуре - эти ВВ импульсы дают увеличение энергии колебаний тока в резонансном контуре.?
[1.3 из 4] (восстановлен через 1 месяц после удаления данного коммента, возможно автором канала)
Накачка пушпулом колебаний в резонансном и съёмном контуре
Вынужденные колебания тока в катушке-индукторе (в резонансном LC-контуре) возбуждаются (накачиваются) двуполярными прямоугольными импульсами тока от двухплечевого генератора пушпул (два ключа мосфета IRFP 260) через трансформатор на ферромагнитном горшке, через два плеча пушпула в виде обмотки 12+12 витков (если питание 24 В), а если питание 12 В то в плечах 6+6 витков. Оба плеча намотаны на горшке в одну сторону, т.е. из одной обмотки на горшке 24 витка (если питание 24 вольта) посередине просто сделан отвод, и этим образованы две одинаковые половины обмотки (плечи).
Энергия накачки в виде импульсов тока, от источника питания через ключи, по очереди, от плеч пушпула передается по горшку-магнитопроводу в обмотку 3-4 витка, включенную последовательно с катушкой-индуктором в резонансный LC-контур, в контур входит также конденсатор.
Одновременно импульсы тока от обмотки пушпула передаются в обмотку 26-28 витков в съёмном LC-контуре, куда также входит катушка-бифиляр (граната), и конденсатор (или 2 конденсатора). То есть пушпул одновременно раскачивает (накачивает энергией) второй, съёмный LC-контур.
В данном генераторе СЕ 1 пушпул через 1 трансформатор (на ферритовом горшке) накачивает энергией оба LC-контура синхронно, в одной фазе, без сдвига фазы между накачкой пушпулом резонансного контура, и съёмного контура.
Если накачивать не 1, а 2 пушпулами, каждый со своим трансформатором - т.е. один на резонансный, другой на съёмный контур, то можно регулировать сдвиг фаз между 2 накачками, значит между фазами 2х колебаний в 2х контурах. Можно регулировать амплитуды и заполнения 2х накачек прямоугольными импульсами тока, значит влиять на амплитуды 2х колебаний в 2х контурах. Обе накачки импульсами тока по-прежнему создают встречно-чередующиеся магнитные потоки по 2м ферритовым магнитопроводам (постоянно перемагничивают ферриты). Меняя сдвиг фаз и соотношение амплитуд колебаний токов в двух взаимодействующих LC-контурах - можно влиять на режимы обмена (передачи) энергии между контурами.
Полупроводники пушпула и ФАПЧ
Управляющая пушпулом микросхема - стандартная TL494. Два полевых транзистора-мосфета (два ключа пушпула) - типа IRFP260, они включаются-выключаются через драйверы мосфетов типа TC4421 (максимальный ток до 9 А). Обо всем этом Руслан рассказывает в своих видео.
Подстройка генератора пушпул по частоте и фазе (ФАПЧ - если есть), для поддержания максимального размаха колебаний тока (резонанса) в резонансном LC-контуре (индукторе) - сделана на стандартной микросхеме CD4046 (Phase Locked Loop = ФАПЧ).
Несущая и пачки импульсов в генераторе Теслы
Также возможно используется иногда вторая TL494 в генераторе на Теслу для генерации пачек импульсов (низкочастотная прямоугольная огибающая для высокочастотной несущей), в зависимости от варианта схемы этого генератора. Т.е. для создания управляемой прямоугольной низкочастотной модуляции по амплитуде (от нуля до максимума), несущей высокой частоты (или просто несущая) от генератора Теслы.
Несущая - это последовательность высокочастотных (~1,5 МГц) прямоугольных однополярных импульсов тока, через ключ мосфет генератора Теслы. Очень желательно, чтобы несущая была точно на собственной (резонансной) частоте системы 3 катушек: ВВ Теслы на заземлении + шняга + антенна.
Степень, доля заполнения импульсом тока каждого периода несущей (параметр duty cycle), т.е. отношение "длительность импульса/длительность периода" - регулируется ("длительность периода = длительность импульса + длительность нулевой паузы"). Иногда этот параметр называют также скважностью.
Duty cycle должен быть стабильным.
Подбор duty cycle несущей важен для получения максимальной однополярности ВВ импульсов Теслы.
Микросхемы 74HC00 и 74HC14 в генераторе несущей высокой частоты
Очень вероятно, что Кулабухов использует также микросхемы 74HC00 (4 логических элемента И-НЕ, каждый с 2 входами и 1 выходом), или 74HC14 (6 триггеров Шмитта с инверсией на выходе НЕ, каждый с 1 входом и 1 выходом).
И на элементах И-НЕ, и на триггерах Шмитта с инверсией на выходе НЕ - можно собрать генераторы прямоугольных однополярных импульсов (т.е. генераторы несущей, в устройстве нужна частота до 2 МГц), если добавить цепи обратной связи с конденсаторами и резисторами, и добавить если нужно другие элементы (например быстрые диоды) - т.е. если создать обвязку для этих микросхем 74HC00 и 74HC14.
Работающих схем таких генераторов достаточно много.
Регулируя параметры элементов RC обвязки (сопротивление, ёмкость), особенно в цепи обратной связи - можно изменять частоту генерации прямоугольных импульсов, и степень заполнения в последовательности импульсов (duty cycle, или скважность).
Серия микросхем 74HCxx - относительно быстродействующая (время переключения логического состояния между нулем и единицей порядка 3-4 наносекунд). Поэтому передние и задние фронты прямоугольных однополярных импульсов на этих элементах получаются достаточно крутыми.
Другие элементы в схеме
Руслан постоянно использует стабилизаторы напряжения 5 В и 12 В на радиаторах, для питания микросхем, драйверов мосфетов, и всех узлов схемы в целом.
Также он постоянно использует сглаживающие (фильтрующие) конденсаторы (неполярные относительно небольшой ёмкости, и полярные электролитические большой ёмкости) в цепях питания. Он использует фильтрующие цепочки типа LC, CR, просто дроссели-индуктивности L в цепях питания, и не исключено - в цепях управления.
Полупроводники генератора Теслы и выпрямительного моста
Сначала на индуктор Теслы у Руслана работал биполярный транзистор npn Toshiba 2SC5200, в схеме качера.
Затем в генераторе на индуктор Теслы работал полевой транзистор-мосфет IRFP460, включаемый-выключаемый через драйвер мосфета TC4421 (максимальный ток в импульсе до 9 А), сначала в схеме качера, затем в генераторе.
Затем Руслан использует как ключ на индуктор Теслы более подходящий мосфет 2SK1162, с драйвером TC4451 (до 13 А), в генераторе Теслы.
Похожая ситуация и для силовых ВЧ диодов в выходном выпрямительном диодном мосте. Назывались разные диоды: STTH12R06DI, MUR860, возможны и другие типы.
Драйверы мосфетов
Мощные сильноточные мосфеты имеют немаленькую входную ёмкость (затвор-исток) порядка несколько нанофарад (1-2... до 8 нФ). См datasheet-ы разных мосфетов.
Чтобы полностью открыть мосфет (уменьшить сопротивление исток-сток до сотых долей ома - см datasheet мосфета), надо поднять напряжение затвор-исток приблизительно до 10-15 вольт (для разных мосфетов различается). То есть надо зарядить некий конденсатор на входе мосфета до этого напряжения. То есть нужно передать определенный электрический заряд на затвор, создать ток, заряжающий входной конденсатор мосфета. Чтобы это сделать быстро (за наносекунды), надо достаточно большой ток, несколько ампер, или десяток с лишним ампер.
Эту операцию - очень быстрая зарядка-разрядка входного конденсатора мощного мосфета - хорошо выполняют как раз специализированные драйверы мосфетов, они созданы собственно только для этого. Драйвер может управляться напряжением +5 вольт (и небольшим током) от логической схемы управления (команды включить-выключить ток на затвор мосфета и зарядить-разрядить входной конденсатор, т.е. открыть-закрыть мосфет), может иметь отдельное питание до +18+20 вольт, и достоточно большой конденсатор параллельно этому питанию - как раз они через драйвер заряжают-разряжают входной конденсатор мосфета.
Все подробности, и типовую схему включения конкретного драйвера - см в datasheet-ах к драйверам мосфетов.
Быстрое (2-3 десятка наносекунд) включение-выключение мосфета создает крутые передние и задние фронты в импульсах тока через мосфет, от источника питания.
Крутизна фронтов в импульсах тока
Крутизна фронта в импульсе тока - это первая производная dI/dt функции (графика) тока I от времени, причем тока проводимости (не тока смещения).
По уравнениям Максвелла этой первой производной по времени d/dt (скорости изменения чего-либо во времени, в данном случае тока проводимости) - из диф. уравнения пропорциональны в явном виде - d/dt от ротора напряженности магнитного поля H (rot H) и крутизна (d/dt) тока смещения, и косвенно (через другое сопряженное диф. уравнение в системе диф. уравнений Максвелла) пропорциональна d/dt от ротора напряженности вихревого электрического поля E (rot E).
То есть ей, крутизне тока в импульсах, пропорциональны крутизна тока смещения в эфире, и все скорости изменения электрических и магнитных полей: во времени (d/dt) и в пространстве (rot).
То есть все переходные и периодические во времени электромагнитные явления - в устройстве происходят несколько быстрее и с бОльшей амплитудой (размахом) - если эта крутизна фронтов в импульсах тока больше.
Кулабухов и прогресс
Руслан не стоит на месте, а непрерывно работает, исследует процессы в катушках, изменяет узлы общей схемы и пробует что получается. То есть он постоянно экспериментирует. И при этом он снимал ранее, и регулярно снимает сейчас очередное видео.?
(2017.01-12) Папка на Yandex-диске со всеми моими комментами к данному ролику
Название папки - "Генератор 4 киловатта (демонстрация в лесу)" (то есть как название данного ролика)
https://yadi.sk/d/uhrAK552zunFC
Другая папка на Yandex-диске, с другими моими комментами к этому же ролику на другом канале (там лежит копия данного ролика).
Содержание тех коментов в чем-то близкое к данным комментам, то есть там тоже какие-то подробности по устройству, и некоторые принципы работы данного генератора СЕ.
А также там есть комменты по аналогичному генератору СЕ Сергея Алексеева (он похож на данный  генератор, но с определенными отличиями и усовершенствованиями).
Название папки - "Демонстрация генератора @ ВТвКД"
https://yadi.sk/d/56Asqd-h32aQz6
А именно, в ней смотреть сначала вложенные подпапки:
подпапка "#1 Tapac MOP3E Мысли вслух"
подпапка "#2 Занимательная арифметика".
Можно глянуть в другие 2 подпапки в папке, из любопытства.
color
This person is a person who does not understand the ground used by free generators.
This writer is a person who does not know the principle of Ruslan Generator.
I guess this is one of the crackers.
