Critique My Free Energy Idea, Please
Started by Eighthman, February 04, 2019, 03:14:08 PM
Eighthman
https://www.google.com/search?q=bertil+werjefelt&rlz=1C1NHXL_enUS703US703&tbm=isch&source=iu&ictx=1&fir=_yxskLXTejFdXM%253A%252CJbQXEwIdc4pCMM%252C_&usg=AI4_-kSb1q0Ln98f8DAnJMtm4rL3gy-fjg&sa=X&ved=2ahUKEwj8g_a5xKLgAhVBKqwKHUfMDx8Q9QEwBHoECAYQBA#imgrc=_yxskLXTejFdXM:
I would like to modify a "Werjefelt Magnetic Battery".  His device is impractical because you can't get attracting and repelling poles to match up precisely in rotation.  Magnetic attraction tends to focus narrowly while repulsion tends to splay out widely - so that getting them to physically balance out is ridiculous ( in rotation).
However..... suppose you built a generator that reciprocated? With attraction and repulsion moving back and forth, while generating current?  This way the back and forth motion gets canceled out as to any effort or physical resistance.  A generator that doesn't resist or cog, moving freely.
Werjefelt claimed a degree of success in his invention but I think trading reciprocation for rotation to be the practical solution.
F6FLT
Quote from: Eighthman on February 04, 2019, 03:14:08 PM
You can do it but only when current is not drawn. When current is drawn, the reciprocity is broken because the field created by the current will oppose the attraction or the repulsion or both, depending on couplings. If the reciprocity was kept, there would be no more reason for charges for feeling an EMF.
Eighthman
http://www.rexresearch.com/werjefelt/werjefelt.htm
Werjefelt was not a crackpot but a serious, practical engineer and inventor.  He and Japanese found overunity (in vs out).
The patent claims to describe (as parts of 360 degrees) such that attraction can be compensated for.
ramset
Quote from: Eighthman on February 09, 2019, 09:11:32 PM
sir
  IMO there can be no doubt this man and his work would have been held to high standards  ,having my early training in Aircraft for the aerospace industry ...the Bar is set the highest and the scrutiny  of such a man would be very strong . he would most certainly know how to do proper testing [and his methods placed under extreme rigor.. as well his reputation]...and then you add the Japanese to the mix ...IMO a culture that would ostracize a scam mentality . It is very odd that this is soo old a claim and no more results ?
very timely contribution in my opinion ,and there are certainly menbers here who would experiment if
bench testing showed promise
respectfully Chet K  Ps to add
any more info on this man and his work from any members would be greatly appreciated...I will surely le looking for more info
Thanks Grandma
norman6538
If there was no counter to motion Lenz force then all generators would turn with only the
friction required to rotate it. So until you get there you have no progress. I have always maintained
that if we can get a small force to release a larger force then we have OU. So you can compress
a spring and latch it and release it with a small force but then you have to compress again to
see the released force. I do have a permanent magnet setup that does have more out than in
but it does not have enough to make it self run. It needs 300%-400% to do the set and reset
switching. So I do have hope that it can be done.
Norman
