Here is the machine that could make the BIG BANG
Started by geptole, February 28, 2019, 10:02:01 AM
geptole
(it is traslated by google chrome)
These are simply 2 rotation axes placed perpendicular to each other (a carpenter would say "in team")
If 2 axes of rotation are required, then 2 electric motors are required.
To distinguish them in the drawing one engine is green and the other is pink.
The purpose of the pink engine is to generate a very strong gyroscopic effect, so strong as to be almost inflexible.
The purpose of the green engine is to quickly rotate the rotation axis produced by the pink engine.
The effort to make the green engine is gigantic because the gyroscopic effect generated by the pink engine is gigantic.
The pink engine must perform 400,000 rpm, instead the green motor must perform 200,000 rpm.
Both engines must be inside a room where there is high vacuum, and also there must be a temperature of a few degrees kelvin: 1 or 2 or 3.
The fans of the engines can not cool the engines because as already explained above, in fact inside the room is not air because there is an extreme vacuum.
Although the fans can not cool the engines, the windings do not heat up because a few degrees kelvin triggers the strange phenomenon called "superconductivity".
Superconductivity allows you to create very strong magnetic fields and the green motor provides a huge torque, able to overcome the gigantic gyroscopic effect.
I remember that the gyroscopic effect has the tendency to keep the axis of rotation fixed in space.
The gigantic pair generated by the green engine should generate heat or potential energy, but it does not generate any of the 2 forms of energy, so it seems that the famous law of energy conservation is not respected.
In fact: in order for the law of conservation to be respected, it must necessarily happen that the ("space_time") that is above the pink motor must start to turn on itself and then accelerate with a rotary motion.
Even if the room does not turn on itself it is as if it were turning on itself and any non-bound objects that are inside the room would be pushed outwards against the walls of the room.
Incredible! An outside observer sees that the room is still but sees that the objects are pushed outwards and even the observer himself feels a force that moves him away from the room itself.
The rotation of ("space_time") generates the expansion of ("space_time"), right where there is the imaginary center of the rotation axis B.
Subsequently the same conditions are created that existed before the famous BIG BANG, which already occurred about 13.7 billion years ago.
Before the BIG BANG there was no ("space_time").
When it occurs that the ("space_time") does not exist, an external observer could see that time flows at infinite speed and therefore everything becomes probable ... Also the BIG BANG.
The extreme dilatation of the ("space_time") that occurs above the pink engine causes a tearing of the ("space_time") and bursts the BIG BANG.
The destructive power of the artificial BIG BANG is exactly the same as that which occurred 13.7 billion years ago, impossible to write the number of megatons, it would take many numbers with many exponents on top of each other.
F6FLT
What is the length of the axis separating the flywheels, and their mass and moment of inertia?
geptole
1) Consider a professional bench grinder with 2 grinding wheels (see the example picture)
2) Measure the distance between the wheels, that distance is fine!
3) Replace the new grinding wheel with a steel flywheel of the same geometry and size.
4) Disassemble those flywheels and put its on a weight meter and weigh its.
5) Knowing the weight of the flywheel and the acceleration of Earth's gravity, you can calculate the mass.
6) the encumbrance of the green engine must be at least 4 times the encumbrance of the pink engine, so the plate power of the green engine must be at least 16 times the plate power of the pink engine.
7) Now you have all data you need, so you can speak to a university student and tell him to calculate the moment of inertia.
I can not calculate because I have not weighed
geptole
it is possible to make the big bang machine even with an ONLY motor, but in this case the 2 flywheels cannot be of the same geometry.
One must have a crown gear, so a bevel gear pair is required.
In this case of a single motor, the brushes are not necessary but there is the friction of the gears.
Low-Q
This device have for sure many applications. Not only does it make time go faster, and takes away gravity, but also create The Big Bang. Well, the suggested singularity before The Big Band contradicts the zero gravity theory you got. I would assume that, if the whole universe once was packed into a point with no extent, the gravity should be insanely strong, and time stops.
I am soon finished with a better flywheel pendulum. I will post the result in your "Time"-thread.
Vidar
