How to make an anti-gravity barrier
Started by geptole, March 04, 2019, 04:54:39 AM
citfta
geptole
Many thanks for the test. ;D
I counted 18 swings with the flywheel stopped, with a flying flywheel I couldn't count well because you put your hand in front.
Then I could not see the fulcrum above which could not see the rotation axis B.
What was it costing you to put away the video camera a bit?
Then the bearing must be 100% rigid.
In that case, while the flywheel is spinning, the number of oscillations should be less than 18, otherwise what is written on the books is not true, ie is not true that gyroscopic effect keeps the rotation axis in space.
