How to make an anti-gravity barrier
Started by geptole, March 04, 2019, 04:54:39 AM
geptole
The magnetic force prevents the realization of the anti-gravity barrier, if there is only the magnetism of the Earth it is fine because it is weak.
The magnetism must stay closed inside a stator carcass of an electric engine.
geptole
it is possible to make the anti-gravity barrier even with an ONLY engine, but in this case the 2 flywheels cannot be of the same geometry.
One must have a crown gear, so a bevel gear pair is required.
In this case of a single engine, the brushes are not necessary but there are gears.
Low-Q
It's not possible to make an anti gravity barrier with this one.
Vidar
tinu
@geptole,
For a start, I'd be perfectly happy with a simple gravity barrier. Or with the faintest anti-gravity force as well. As about an anti-gravity barrier, that's way, way above my head... :)))
Regarding the 2-motors device as depicted on page 1, imho I'd say it would be a great way for shifting the axis of Earth. Ok, it would change it so slightly but hey, we can start from there and move on, can't we? At least we will save the energy conservation law for a bit longer and who knows what else we can solve in the future by tilting the Earth?! Maybe even solve the global warming problem with a couple of bigger motors? And I'm pretty confident that if the motors are made big enough as to spontaneously collapse into a rotating black hole, then we'll surely be able to measure a spacetime-drag effect. Then we can talk! But we have to stay at a safe distance from the black hole, for obvious reasons. Not sure about the 'gigantic explosion', though. Are you thinking of a Big-bang type? I mean, is it possible that our entire universe was created by someone playing with a couple of gyros? I never thought anything like that until now... Fascinating! I'm keyboard-less.
F6FLT
Quote from: geptole on March 06, 2019, 05:52:11 AM
Higher is rpm, higher wil be the effect of the barrier.
There is no equation, simply 40 thousand rpm is the maximum speed an electric motor could do.
the rpm of green engine must be less because there does not want gyroscopic effect
So to understand each other better, starting now, the pink engine is gyroscopic engine and the green engine is main engine.
In "The pink engine has to do 40,000 rpm", "has to do" means a necessity.
If "40 thousand rpm is the maximum speed 40,000 rpm an electric motor could do", not a necessity, why the maximum speed would fit the needed speed?
Why?
Even if there was an effect, which is infinitely unlikely, you have no idea if it is strong enough to be detected.
Instead of talking nonsense or whatever comes into your head, you have to quantify the effect.
