How to make an anti-gravity barrier
Started by geptole, March 04, 2019, 04:54:39 AM
shylo
Without some kind of anchor point, how can a gyroscopic effect be produced?
If there is nothing to apply force against, how can a force opposite pop into existence?
artv
F6FLT
Quote from: geptole on March 05, 2019, 04:38:41 PM
I apologize, I forgot to draw the connection of the wires and brushes
This doesn't not answer the questions :
Why "The pink engine has to do 40,000 rpm, instead the green motor has to do 20,000 rpm"?
Please show us the equations.
There can be no "anti-gravity barrier that prevents gravity from passing" because gravity is a deformation of space-time, there is no gravity flow (only gravity waves, irrelevant here). If you think relativity is no longer valid, how do you explain the extension of the lifetime of radioactive particles accelerated to a speed close to that of light?
geptole
Higher is rpm, higher wil be the effect of the barrier.
There is no equation, simply 40 thousand rpm is the maximum speed an electric motor could do.
the rpm of green engine must be less because there does not want gyroscopic effect
So to understand each other better, starting now, the pink engine is gyroscopic engine and the green engine is main engine.
Low-Q
@ geptole,
As I wrote in your other thread about the same device, the motor isn't fighting gyroscopic effect.
Please read my post:
https://overunity.com/18178/the-time-machine/msg532523/#msg532523
Vidar
Quote from: geptole on March 06, 2019, 05:52:11 AM
An electric Motor can have ultra-high RPMs :
https://www.google.com/search?q=ultra+high+RPM+motor&safe=active&client=firefox-b&oq=ultra+high+RPM+motor&gs_l=mobile-heirloom-serp.3..0i22i30l2.17231.32500.0.33203.34.23.0.6.6.3.251.2835.1j17j2.20.0....0...1c..34.mobile-heirloom-serp..12.22.2240.ouQcxdzOYvo
Normal calculation for bearing life-time : 3000 RPM ~ 20.000 hours ( twenty thousands ) ~ 3,6 billion Rounds
