Radiant power from Solid state Tesla hairpin circuit
Started by evostars, April 19, 2019, 09:55:08 AM
gyulasun
Hi Mike,
Well, I think the resistor is connected to the coil and not to the relay closing or opening contacts.
Either in paralell with the coil or in series,  I think mainly in paralell, especially when a diode is used, this latter may be in series with the resistor and this series R - D combination would go in paralell with the coil, to tame the spikes at relay coil switch-offs.
Gyula
nelsonrochaa
Quote from: Hoppy on May 13, 2019, 12:39:28 PM
One of the original relay free energy videos.  ;) :)
https://www.youtube.com/watch?v=bSZzy4LB5uE
Hi hoppy ,
I can certainly say that they are not the same or similar circuits, and that they both demonstrate absolutely different things, and of course no free energy circuit like you title them.
The circuit i show some years ago , able to show more than Voltage in output .
https://www.youtube.com/watch?v=C9Ozeq61x1Y
Cheers
nelsonrochaa
Quote from: evostars on May 12, 2019, 06:32:14 AM
The Radiant solid state circuit I shared on 19 April 2019 has more possibilities.
It can also be used for Health benefits. Nikola Tesla described it already in 1898 in Buffalo. A link to this document can be found in the video description.
When the Load (28W lamp) is removed from the L3 coil, the energy  keeps surrounding the L3 coil in its electric fields. You can use this Radiant energy for health benefits.
Link to the video "Radiant Health Radiant Health Benefits From Solid State Tesla Hairpin Circuit":
https://youtu.be/5uaNpeYKO74
Hi
I would like to leave an opinion on this subject as it is concerned with public health.
One of the things that I warned Master Ivo when I shared details of the circuit for him to recreate was that he should use an electrostatic wristband due to health problems associated with the circuit in question.
During the process of tuning the circuit, people are exposed to several frequencies that are guaranteed in no way good for health.
I myself, and some people who tested the circuit became sick and exhausted during the time they used the circuit.Radiant energy is only beneficial to health, if the right freq is chosen, something that I am sure is not known to the general public.
It is completely unwise to give this suggestion knowing that there are associated health problems if the right choices are not made.
This is only a Warning .
Cheers
Hoppy
Quote from: nelsonrochaa on May 21, 2019, 05:26:12 AM
Hi hoppy ,
Cheers
Agreed, clearly not FE IMO, thus the winking emoji at the end. However, I'm sure that some still believe that the HV 'radiant energy' charged cap stores some FE, thus why the vibrating relay cap charging concept videos found a home on FE forums. Thanks for posting a warning of the potential hazard to health in experimenting with HF / HV devices.
magpwr
Quote from: nelsonrochaa on May 21, 2019, 05:38:20 AM
Hi
Cheers
hi nelsonrochaa,
Thanks for your health tips.I did felt strange/weak after i worked with nanosecond generator 1kv <10ns pulse posted in my youtube few years ago.
Although i was aware at that time high voltage nanosecond pulse can be used for sterilization for drinks to rid of bacteria and etc.
In the meantime i have attempt to reverse engineer and tried to derive a circuit schematic from this video of yours.Not tested at this point since i need time to find a used microwave transformer.Hope you don't mind since you mentioned it is not FE.
ENERGY AMPLIFICATION "Recovering and convert radiahttps://www.youtube.com/watch?v=F7EkHm08Te4
All caps value are estimates only.
