Four rod magnets and two one way bearings = free energy???
Started by magnetman12003, May 06, 2019, 08:18:28 PM
magnetman12003
Quote from: magnetman12003 on May 15, 2019, 05:59:29 PM
Quote from: magnetman12003 on May 14, 2019, 06:29:52 PM
Quote from: skywatcher on May 14, 2019, 06:06:31 PM
It's always the same error in reasoning.
Any construction involving only permanent magnets and other passive components will only move until the equilibrium of forces is reached, and then it will stop.
[/quote
Worth trying anyhow with four heavy magnets free to bear down at 45 degrees on lower magnets.
Something has to move.  Anyways here is a photo showing the four magnets I will put into 45 degree pipes where they will be free to slide.  Might even try 22.5 degree also.  I am using a top circular plate instead of arm which makes things easier.  My other 4 magnets are secured inside the cylinder.   Tom
I was giving thought about using a thin gum rubber disk under the disk that has the 45 degree magnet pipes mounted on.  That way the 45 degree magnet disk won't be able to slip around on top of the 4 vertical magnets under it because of the weight of the 45 degree magnets pressing down.
So now the the need of any link between the top 45 degree magnet disk and the cylinder the vertical magnets are secured inside is not needed.   Tom
