Four rod magnets and two one way bearings = free energy???
Started by magnetman12003, May 06, 2019, 08:18:28 PM
magnetman12003
Thanks Gyula for your input on this.  I already installed the one way bearings and as you stated without
a squeeze the setup stops rotating.   I now know how to apply the squeeze all the time using gravity.
Will post later my results.
magnetman12003
Quote from: magnetman12003 on May 11, 2019, 01:58:52 PM
Will post this later.
Picture a HEAVY rod magnet coming in at a 45 degree from the top side of a arm and DIRECTED right at
A lower arm magnet that is mounted VERTICALY.  Both magnets now repel each other ALL THE TIME.
Both magnet are inside PVC  pipe mount tubes which allow them to be removed if needed.
A one way bearing is mounted on the top arm to keep the 45 degree rod magnet from being repeled counterclockwise. The bottom arm rod magnet must move clockwise and if its linked to the top rod magnet
It may drag it with it continuouslyl?????
I am waiting now for more parts on my build.
Tom
gyulasun
> The bottom arm rod magnet must move clockwise and if its linked to the top rod magnet> It may drag it with it continuouslyl? ??? ?
> Tom "
Hi Tom,
Please try to make a drawing by hand again because it would clear any misunderstand that may come from your description.
Thanks
Gyula
magnetman12003
Here is a photo of what I was talking about.  Might need resized by someone?
Thaelin
seems that I saw a  YT vid of this but for the life of me, cant find it. Me just see
things or was it there?
thay
