Real overunity transformer with ancient technology
Started by IonLady, May 08, 2019, 04:30:40 AM
IonLady
Dear All,
This is a good info for all !!
I'm looking for all the designs and models of overunity transformers, I want to share the info I got from the results of the post before, you can see it here
https://youtu.be/ybzLpOypSDs
what is your opinion ?
Thank you
Best Regard
About AlvaroCS21 his comment I am not satisfied :
Indrawan uses such material for the primary :
https://en.m.wikipedia.org/wiki/Zinc%E2%80%93carbon_battery
Imris "Band-/Foil"-Condensator/Capacitor in his transformer
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=42&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990812&CC=DE&NR=29910512U1&KC=U1# Aluminium and Copper, in vaccuo
AlvaroCS21 : did he ever saw an applicated  Dr. Imris device on video or real life in function. ?
BTW : the Imris transformer application has never been officially approved and granted
Mr. Indrawan is demonstrating openly " a conversion process".
We do not know about his intentions, his concept economical potentials ( work-hour/ lifetime/ charge cycles).
I see him ,Yusuf Indrawan,  in a list with Lasersaber and Gerard Morin.
R.Friedrich ? Let us see
The well qualified german Capacitor producing company  http://www.bkprenzlau.de/  have had really technicalproblems to translateDr.  Imris physical numbers in ready and really to use Band-/Foil-condensators.
tonygiang
Hi all!
perhaps that, should Indrawan 's COP be so big!
tonygiang
Hi  lancaIV!
I has a question : Why is this transformer  "use in resistive loads" only? inductive load ?
Without transformer details I can not give an answer  !
In geral :
Resistive loads are less sensitive to pulsed DC~ AC,  for inductive devices likemotors you need the right RPM/Hz ratio ,the common 50/60 Hz ~ 3000/3600 RPM.
Assumption :
Variable speed/frequency controler probably for his transformer needed if inductive loads charging !
Best solution :
asking him, Mr.Indrawan, by e-mail directly or waiting for his next disclosure and development steps
