Revolutionary Air Conditioner!
Started by gravityblock, July 04, 2019, 05:11:55 PM
gravityblock
This video, explains the design and principles behind a revolutionary desiccant based air conditioning. This extremely efficient, DIY air conditioner, is inexpensive to build and costs less than one half as much to run as a conventional, compressor based air conditioner.
Gravock
Kator01
Hi gravock,
just discovered it yesterday. This man is really profound in the way he is preparing his demonstrations.I have to go through all the other related videos first he refers to in the descritpion to get more into the details of this technique.I dont understand some details he presents as he obviously presumes some basics which I am missing.So I will come back to ask some questions and maybe you can help me with some explanations.
I am convinced that this technique will be of big importance as out solar system is undergoing a serious change which is not communicated since 1965 whenthe book "The Adam and Eve Story" was published and the CIA the immidiately did a serious reseach on the subject of the so called "Earth Catastroophy Cycle".The results of this investigation was classified until 2013.You find the subject  on SuspectSky.
https://www.youtube.com/watch?v=TA9xrryDU5c
This guy is a close friend of Ben Davidson http://spaceweathernews.com/
To make it more clear there is more than one cause for the problemns to come which you can read here about what the Russians published in 1998:
https://abruptearthchanges.files.wordpress.com/2016/11/dmitriev2.pdf
So we learn that our solar system has entered an enormeous very hot plasma-cloud ( the dimension of this cloud is about 30 lightyears ) and all planets are affected andmust rebalance and so does out earth. Planes are heated up from the core, no man made climate-change.
Futher study is here : Dr, Dunning and his speeches on the "Observing the frontier conference" which is organized by Ben Davidson
https://www.youtube.com/watch?v=XVl-RaL-ZsQ
https://www.youtube.com/user/ldunning48/videos
Sorry if I got off topic here but I think its important to know
Mike
Floor
@ RebeccaKerr
The desiccating evaporative system demonstrated, handles pretty small BTUs.
A greater BTU system (enough to cool an entire home)
might be in terms of its physical dimensions, pretty large.
When it comes to conventional evaporative coolers, there
are several concerns.
1. They don't work in high humidity environments (i.e. when it is raining).
2. They require a lot of maintenance, due to minerals accumulating on the
evaporation surfaces and minerals concentrating within the water reservoir.
3. They consume a lot of water.
4. One cannot re cool the air once it has been humidified by passing it through
the cooler again. Therefore they cannot function in an air recirculating modality.
Dry air must continually flow into the cooler and therefore also, other air must be
pushed out of the house.
5. They need to move a lot of air in order to be effective.
Of the  desiccating evaporative system several things come to mind.
Humid environments are some times very humid.  The desiccating components
might need to be of a considerable size in such circumstances.
Hot, dry environments tend to have a lot of dust in the air.  That dust will accumulate
in the desiccating evaporative system, reduce efficiency and at some point create the
need to clean the insides of the system. Replacement of the desiccating liquid and /or
the evaporative surfaces may be required.  Some considerations of environmental
impacts is merited in this regard.
This is a Little or no fresh air system.  Cool or not, and like refrigerated air, it will
tend to become "stale" after a while.
Questions I would explore.
Does it lose water over time ?
If so, what is the water consumption rate in this kind of system, not optimistically
but realistically ?
What is the range of air humidity (interior) it is likely to maintain.
What is the range of air humidity (exterior) it is likely to  best and / or properly
function within ?
How far does efficiency drop if the system is dirty ?
What is its ease of maintenance comparable to ?
How likely is it that pathogenic organism will propagate within the system
as compared to conventional evaporative cooler systems ?  Conventional
coolers have saturated / intensely  salty water.
NathanJackson
A very intriguing discussion is happening here. A revolutionary air conditioner. Of course, there are several concerns, because is not still explored to the fullest. You're right that hot and dry environments tend to have a lot of dust in the air. But if you do have a simple aircon, then you must remember to clean it from time to time.
