Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
Turbo
Quote from: forest on September 23, 2019, 02:00:45 PM
The energy probably comes from Earth magnetic field. SM mentioned it at least twice.
If you answer like this please post the exact reference.
Like this:
I mean we believed very strongly that the power we converted came from the earth's magnetic field.
We believed that mainly because it is the obvious choice.
However please consider that we had no way of confirming exactly where the power comes from.
I am not sure how anyone would confirm that at this point.
And it isn't really important at this juncture.
All we can do is build bigger and better power units and continue our experiments till we do know for sure exactly what we are dealing with.
This is exactly what I said to Dr. Schinzinger the first day I met him.
I blatantly admitted that we knew how to make the music but had no idea how the violin worked.
ramset
Just a note,Turbo has been at this for a long time ,he is not a newbie and has put more time into this than
can be measured .
As Turbo has mentioned .... today the tools to play [system management] are better than ever before and cheap too.we are also trying to get a funding method here for builders.
Also  members here are trying to get some important "bits" which may shed more light.
In the mean time ...Turbo has a very cogent direction ,from years of reverse engineering and hands on testing and experience.
exciting times indeed.
Turbo feel free to remove any inaccuracies in my post [or the whole post if?]also if you could remove or try to remove my test topic here https://overunity.com/18337/new-board-test/msg539226/#new [it may cause confusion]
if not ...no worries
much gratitude from here,
  Chet K, PS, there are certainly PLENTY of talented TPU fellows in the house...
Thanks Grandma
WhatIsIt
"About the collector:
It is three separate coils of  multi strand copper wire laid one on top of the other, not interleaved. "
The collector coils are on top of the other.
Three is important.
You can do many things  with three coils.  You can run them  in parallel, you  can run two in series and one in parallel, or etc
You can run a separate  frequency into each coil  for  better control on large power units if need be.
Is this mean that only one frequency is used, but separate frequency can be used in each coil?
The control wiring is vertically  wound in several segments around each of the horizontal collector coils.  Other control  wires are wound around all  of  the  horizontal collector coils together.
Here, the collector coils are horizontal?
First, the 3 collector coils are on top of each other, then collector coils are horizontal?
It makes no sense. How this arrangement looks like?
It also indicates only one frequency for all 3 coils? Separate frequencies can be used if needed?
I am little bit confused with this arrangement.
tomd
QuoteWell as soon as I get my amp finished I will let you know if I have any
more problems with it.
But I like the sound and the power of it already.
Take care.
Sincerely,
By the way.
I have really THOUGHT about how to help you and the others.
I can not tell youtoo much about the design of the technology because the
company
who still owns the technology is reading my every word, as you know and
just waiting
to cut off my pension if I tell you too much.
BUT!
I want you to start and think of the generator principles the exact
same way that passing the sound barrier was accomplished.
Read how the engineers in this country finally developed the proper wing
design to accomplish super sonic speed in aircraft.
I hope it will give you a picture of what is going on inside the generator
and especially the collector.
Imagine that you have a cannon which fires a projectile at a velocity of
1000 miles an hour.
The amount of energy held in the moving projectile until converted is lets
say a figure of ten.
It will never become more then our figure of ten.
The energy will slowly dissipate until the projectile slows and begins to fall
to the ground and it's finale dissipation will occur when it strikes the earth
or the object it was aimed at.
Now, we have been told that there will never be more energy available
from the projectile other then what was given to it when first fired into the
sky, EXCEPT for the following example:
Now, there can be a further dissipation of energy if the projectile was
carrying a charge of dynamite to explode on impact as well.
Do you see how the different things all relate here?
Let me expand your mind for a moment....
Suppose that the projectile which you fired was another cannon?
Now you have another cannon traveling at 1000 miles an hour...
Now, if you could fire the second cannon, the projectile coming from it
would be traveling at a velocity of 1000 miles an hour after being fired.
However, since the cannon is already traveling at a speed of 1000 miles
an hour when you
fire it, the speed of the second fired projectile is essentially now 2000
miles per hour and the energy available to convert from the second     projectile, is now twice the ten available from the first projectile!
You now have energy availability of twenty to convert from the second
projectile.
Now, what if the projectile fired from the second cannon were another
cannon and you fired it.
Since the second cannon is traveling at 2000 miles per hour then the
projectile you fire from it would make 3000 miles per hour, and so on and
so on....
The energy released from the speed of multiple projectiles increases the
energy available to be dissipated upon impact many fold!
The faster the speed of ANYTHING the more energy will be available for
conversion.
A long time ago, i said, if you take a bullet and throw it at the side of an
automobile it
will bounce off.
However, if you place the bullet into a gun and fire it at the automobile it,
with sufficient velocity, go through the metal door and through the other
side because of the inertia energy available for conversion.
Speed is energy if you can convert the mass into energy quickly
enough!
Anything no matter how small can store enough energy to convert
into huge amounts of energy.
Even electrons.....................................
Now, electrons can travel only so fast along the surface of the wire
because of magnetic flux.
What if you disable the effects of the flux?
My unit operates on these principles.
Is he talking about wave superposition or more appropriately pulse superposition?
QuoteIf the unit goes too far on frequency it may begin to convert too
much current and try to dissipate way too much voltage.
[/size]
Is this why the voltages are slightly out of phase considering the energy produced if the waves are in phase?
WhatIsIt
each segment of control coils could be fed a different frequency individually  and or from a collector section to help  perpetuate the oscillationand control.
Here it said that control coils can be fed from collector coils?
Loop?
Another frequency from collector to control?
So many frequencies.
Or they are not different frequencies at all?
Only one?
I am trying to read this and make sense from all of that SM statements.
I dont know!
