Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
WhatIsIt
Quote from: Turbo on September 23, 2019, 11:23:03 AM
These pictures are wrong.
They show interleaved coils.
Hello Turbo!
Do you know anything about this pictures or where they came from?
It seems that you have much more informations that I have.
Can you share your knowledge?
What is wrong with this coils from picture? Are they originate from SM?
How the coils has to be arranged?
Thanks!
forest
The energy probably comes from Earth magnetic field. SM mentioned it at least twice.
crashangel
Quote from: rensseak on September 23, 2019, 06:23:40 AM
As far as I know they are orgin from SM given to Mannix to spreed them to some members only. They had to keept them away from public to prevent SM from going in trouble with authorities.
It was somehow tested but unsuccessful. They have tried but in vain, because everyone has their own imagination and interpretation of what is to be seen.
Everyone builds something different then.What SM said?or thisAnd now look to the way he shows the winding. In my view It might be related to it.
I have been reading all these documents and trying to follow more or less the coordinates that you are giving me ...
It seems that there are different ways to make this work in the form of a small toroid ...
Impressive after so many years this kind of thing has not been released to be reproduced ... In addition to the problem of appearing investors in the future would also be to find good professionals who are reliable and who could be committed to results without taking advantage of the values ​​invested. ..
I thought I'd start with a simple toroid to see if I can get any measurable output ...
There are many metaphorical tracks left in these documents that you can put in the right direction if interpreted correctly ...
I have magnetite powder here and I was tempted to mix it with some resin to create a device seen in these other patents ... But I'll still start with the basics ...
1. As I understand the higher the number of wires in the collector the better for electron pickup .... I am using AWG 34 wire so that the number of turns and number of wires will be significant to answer the control coils .... The thread is so small that each layer looks like a ribbon ... I am making several layers to create only one collecting bobbin, be patient ....
2. The control coil I thought of doing in the Swatooth waveform.
3. For the spacing between one coil and another had a kind of insulating plastic that was in a box that came along with some equipment I bought in the past ...
It seems that the output can be rewired in the input so that the device is powered and also using capacitors, etc ... But this I ask later ...
I accept criticism and suggestions to improve or even redo whatever it takes according to the perception of what you are observing ...
thankful!
Turbo
Quote from: WhatIsIt on September 23, 2019, 01:26:35 PM
Hello Turbo!
Thanks!
No they are not coils from SM.
Those are very wrong in design.
They aren't on top of each other neither vertically nor horizontally because they are interleaved.
Too bad people keep injecting garbage into the tread.
You can use the searchable pdf file to find how its arranged.
Use search terms as collector and control and coils.
Turbo
Quote from: crashangel on September 23, 2019, 03:04:07 PM
thankful!
I see you made another modification to the script.
