Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
rensseak
Quote from: WhatIsIt on September 22, 2019, 04:42:46 PM
Thank you for pictures!
Do you have any information does the pictures originate from SM or that coils were made by Mannix instructed by SM letters?
Anyway, thanks!
As far as I know they are orgin from SM given to Mannix to spreed them to some members only. They had to keept them away from public to prevent SM from going in trouble with authorities.
It was somehow tested but unsuccessful. They have tried but in vain, because everyone has their own imagination and interpretation of what is to be seen.
Everyone builds something different then.What SM said?
Quote from: SMYou know, it is very similar to the idea of a long garden hose.
Picture a hose with water in it.
If you pick up one end and move along the length of the hose you will
move the water constantly along in the direction you are moving.
You could also squeeze the hose in the direction to move the water
along as well.
And you could do both to control the movement of the water more
precisely.
You can think of the movement of water as the movement of
electrons through the collector coils.
or this
Quote from: SMImagine that you have a cannon which fires a projectile at a velocity of
1000 miles an hour.
The amount of energy held in the moving projectile until converted is lets
say a figure of ten.
It will never become more then our figure of ten.
The energy will slowly dissipate until the projectile slows and begins to fall
to the ground and it's finale dissipation will occur when it strikes the earth
or the object it was aimed at.
Now, we have been told that there will never be more energy available
from the projectile other then what was given to it when first fired into the
sky, EXCEPT for the following example:
Now, there can be a further dissipation of energy if the projectile was
carrying a charge of dynamite to explode on impact as well.
Do you see how the different things all relate here?
Let me expand your mind for a moment....
Suppose that the projectile which you fired was another cannon?
Now you have another cannon traveling at 1000 miles an hour...
Now, if you could fire the second cannon, the projectile coming from it
would be traveling at a velocity of 1000 miles an hour after being fired.
However, since the cannon is already traveling at a speed of 1000 miles
an hour when you
fire it, the speed of the second fired projectile is essentially now 2000
miles per hour and the energy available to convert from the second
projectile, is now twice the ten available from the first projectile!
You now have energy availability of twenty to convert from the second
projectile.
Now, what if the projectile fired from the second cannon were another
cannon and you fired it.
Since the second cannon is traveling at 2000 miles per hour then the
projectile you fire from it would make 3000 miles per hour, and so on and
so on....
The energy released from the speed of multiple projectiles increases the
energy available to be dissipated upon impact many fold!
The faster the speed of ANYTHING the more energy will be available for
conversion.
And now look to the way he shows the winding. In my view It might be related to it.
kolbacict
QuoteSo the amplitude of the two merged waves is 2a. However the energy of the two merged waves is (2a)^2 = 4a^2. Before the waves merged there were two waves each having a^2 energy = 2a^2. But after they merged you have 4a^2 energy. So you have doubled the energy by merging the two waves.
It's like in the case of kinetic energy  mV2/2 ,which quadratically depends on the speed ?
In my drawings with spiral paths?
WhatIsIt
Quote from: rensseak on September 23, 2019, 06:23:40 AM
Everyone builds something different then.What SM said?or thisAnd now look to the way he shows the winding. In my view It might be related to it.
Yes, on first look it appears that way.
3 coils wrap around collector coil.
Red, orange and black. And there is one iron wire as well. Could be act as core if frequency is high.
Their combined field will squeze collector coil.
"If you pick up one end and move along the length of the hose you will
move the water constantly along in the direction you are moving."
Does he means that is pulsed DC in all 3 coils wound arround collector will push electrons in one way? Classic induction.
"You could also squeeze the hose in the direction to move the water
along as well."
Does he means the point on collector where all 3 coils, fields combined squeeze the collector?
Another way to move electrons by squeezing. It is not classic induction???
Now, the second thought after your post and looking at picture is connecting  collector back to 3 coils in mobius loop, so output will pass again trough 3 coils around collector feeding collector even more.
So, you need to pulse only one coil to start the avalanche.
I watched YT of TinManPower experiment with that kind of wraping where those 3 coils does not affect source, collector coil.
Whatch it! The core TinManPower used is toroid. It has removed part of toroid, it is seen in another video of his.
It wont work if toroid is whole.
It showed that output does not affect input with wraping like this.
The iron wire on picture can serve as small core if frequency is high.
https://youtu.be/2BfDo5A3Gx8
https://youtu.be/41ZkWUC-zbQ
But its only wild quess looking at this picture and thought!
Have to try to wrap something like this and try and scope to see what happens?
SM said that he does use different kind of induction. Could be this.
Lots of if? But talking is good. Can give some idea.
Thanks!
Turbo
These pictures are wrong.
They show interleaved coils.
Turbo
Quote from: Jeg on September 22, 2019, 07:28:29 AM
Cool.  ;)
SM:
"...The multiple frequencies begin to feed themselves and the
multiple kicks become a combined big kick
But what a kick really is?
Kick, is a current of high pottential and of a brief duration. In other words, kick is a current, with an increased rate of change during a short interval of time.
Now what combination of multiple kicks means for SM?
My very first thought was that more than one kicks coinside together during the same small interval of time. "Occasionally" as SM described. But this is the inside of the box thinking. How the out of the box thinking would be for this case?
ps. Please don't think out of the box all together the same time. There is always the danger of being locked out of it. ;D Jeg
Its safe to say that these kicks are a result of the process and that these kicks deliver more energy then it took to generate them.
Possibly it is nuclear.
Dr. Schinzinger pointed out that during an atomic explosion aside from the gigantic blast wave and heat produced there is also an extremely large magnetic force which is so
strong that it travels way out into space during the explosion.
The magnetic wave is so strong that it will completely destroy any unprotected electronic circuits of solid state design.
That is why solid state radios will be useless after an nuclear attack on your country.
Let us ponder where the huge magnetic field comes from when you explode an atomic bomb.
It is just created?
Is it converted?
Is it part of the earth somehow?
Is it just a by product of the fabric of time and space being ripped into pieces in a fragment of a second?
I am curious as to where this unbelievably huge magnetic force comes from during an atomic explosion...
It is something else to think about perhaps in connection with my power technology.
Dr. Schinzinger said that it is explained as being the result of the splitting of the atom.
However, that is a very short explanation and not really a satisfactory explanation of what generates the force.
He agreed with me and said it would also mean that in reality we know very little about magnetic fields and magnetic property.
Even Steven admitted that he didnt have a clue about where the energy came from.
I mean we believed very strongly that the power we converted came from the earth's magnetic field.
We believed that mainly because it is the obvious choice.
However please consider that we had no way of confirming exactly where the power comes from.
I am not sure how anyone would confirm that at this point.
And it isn't really important at this juncture.
All we can do is build bigger and better power units and continue our experiments till we do know for sure exactly what we are dealing with.
This is exactly what I said to Dr. Schinzinger the first day I met him.
I blatantly admitted that we knew how to make the music but had no idea
how the violin worked.
It's not really important (currently) to know where it's coming from but knowing how to generate it is.
And also how to control and loop it.
