Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
r2fpl
I did the DC test but the situation is the same for AC.
https://youtu.be/6t-WbWIqwhY
Of course, all devices correctly measure the 4ohm resistor
r2fpl
https://youtu.be/1vDRcrw41OI?t=37
Tesla and Kapanadze talked about the impulse. Each of us understands this. The focus should be on how to receive this energy by moving the coil into resonance with this impulse to slow down the response and thus extend the duration of action.
Is this a good explanation. Does anyone contradict Tesla's words when he says the impulse is MW or GigaW of energy ?! Probably not.
However, there are switching power supplies and they do not give more than they get what they do wrong or why it is not so obvious.
d3x0r
@gotoluc
you could maybe just spray down the ground with a hose ... 2k Ohm, that's really high.  Thanks for measuring.
gotoluc
Quote from: gyulasun on September 27, 2019, 06:58:39 PM
Would you check the TX coil operating frequency by a frequency meter (if possible) to see if it changes when you ground its bottom
to the buried copper pipe versus the frequency when its bottom is connected to the 15' wire?
I have retested the setups using a scope and the self tuning resonance circuit stays at 1.1Mhz (TC resonant frequency) connected to wire or grounding rods.
Video demo: https://youtu.be/ISaLhHcMkVQ
Luc
