This forum is turning into trash
Started by ARMCORTEX, September 25, 2019, 04:33:34 PM
rakarskiy
Quote from: onepower on October 24, 2019, 08:45:55 PM
Concerning the forums(s) turning into trash.
I have found we only get back as much as we put into something however many have decided not to share.
70-80% of enthusiasts do not visit such sites at all and do not take part in dialogues, information sharing, discussions.
Here is an example of such an enthusiast.
Generator from Valery Valka (Zhytomyr, Ukraine), a successful sample at 500 rpm has an output power of 0.8 kW. In this case, there is no traditional braking of rotation, with the induction of current in the connection "star". There is no such effect as magnetic adhesion at the star.
https://www.youtube.com/watch?time_continue=1&v=mCKMcJFke_U
http://lipo.ece.wisc.edu/2014pubs/2014-10.pdf
rakarsky,you are right to show specific differences - lower than common rpm- generator related !
For the other side : when a well engineered AC output ( Helmut Schiller )  1 KW/ 3000 RPM generator weights in average  1 kg( with supermagnets) then with 1500 RPM ~ 2 Kg with 750 RPM ~ 4 Kg ( this the common small windgenerator rpm level) and with 500 RPM ~ 6 Kg material input. !
Enthusiasts as individuals can probably afford such higher material investment, but not the average society member. and less the billions of 1-2 $ up to 10$  per day planet Earth habitants !
To conclude a 365/24 permanent working energy converting device in the 1000$/€ range is relatively easy,
the break-even is to construct a 365/24 permanent or periodically  energy converting device in the 250$/€ and less endconsumer price level !
1990-2015 :
many thought that Neodym/Samarium would be the holy grail about " perpetuum mobile" : No  !Other the Fleischmann-Pons " cold fusion"- flasc : No. !Wind and thick film solar cells ! No !
Hydrogen. ! No !
rakarskiy
Quote from: lancaIV on October 25, 2019, 06:37:42 AM
Everything in the world has its price, while in different parts of the world different prices and opportunities. This is the illusion of an ultra-low price for the device. Even if you do it yourself (except when the components are found in a landfill, without payment) it costs money, time and professionalism . Therefore, we can only talk about components, the language is technical, and the pricing policy will always be different for the region and the individual.
The truest thing in the construction of such a device is the traditional knowledge of physics, and engineering savvy. Knowledge in energy and various disciplines to perform the task.
rakarsky,
actual conventual electric device components costs
and a. manufacturing.    b. production   c. b2b/ b2c  price decrease potential :
up to 75% per Kg less
f.e transformer
iron core :
http://www.rexresearch.com/markov/markov.htm
https://www.electronicsweekly.com/news/research-news/magnetically-soft-magnetic-alloy-not-expensive-physically-hard-2019-04/
coil winding concept :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
Primar- y/ies and Seconar-y/ies wiring coil/foil material  :
Instead copper coil /foil: copper world market price / different copper coil diameter and length Kg price. ?
Sodium coil
graphit coil,graphene foil
Aluminium coil/foil.
low cost aluminium production process price :
7,5KWh/Kg electricity a 2,5 US$cents/KWh compared actual 15KWh x 5US$cents/KWh :
1 Kg new aluminium < 0,75 US$ instead industrial average 1,25US$/Kg
Aluminium coil production price by 0,75 US$/Kg material costs : 10-5 US$ per Kg ( diameter dependent)
Markov iron core :  Hz-max. ?
https://www.greencarcongress.com/2007/10/plastic-bonded-.html
Conventional E+I trafo-core, 26 Kg pack : < 5 US$/Kg b2b
New  industrial ferrit-nitrogen magnets production process :
https://arpa-e.energy.gov/?q=slick-sheet-project/iron-nitride-based-magnets
https://www.designworldonline.com/coming-revolution-high-strength-magnets/
  10 US$/Kg announced 8) first arpa spin-offs :
https://nironmagnetics.com/#about
https://fenixmagnetics.com/
https://overunity.com/17176/electro-magneto-dynamic-carnot-cycle/
#4 : powerguru : planar transformer 23$/5 KW in 10000 units production serie/charge
                              question : 5 KW planar transformer power density as KW/Kg ratio. ?
                                                 23 US$/ ? Material weight ?
I would like to see " motor and generator and transformer" - kits in a box, componenents locally 3d-printed like in the image here :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870624&CC=FI&NR=865263A&KC=A#
friction parts easy changeable and these parts refurbish/ recycle-able,also locally !
In Europe(Western") the electrician( with master-degree to be allowed to have a shop/office) in our consume-ware drop away society is a morbid profession.,repair/components offices/shops you will only find in greater cities  !And often the repair service : bad and expensive after the warranty validation . ! Service quality warranty  ?  :P "KULANZ" ???
1 Euro industrial mass production piece as hifi spare part sells for more than 30 Euros in electronic shops. !
Not far away from the total device selling price. ! Consequence : drop away !
Repair time costs per hour : 25-50 Euros + spare part costs
      device worth. ?
https://www-spof.gsfc.nasa.gov/Education/wfluor.html
rakarskiy
Quote from: lancaIV on October 25, 2019, 07:28:53 AM
rakarsky,
Absolutely agree! I did not specify the production and service! Therefore, the motto is relevant to this day: "in our time, to get your hands on a generator of free energy, you need to do it yourself."
The most interesting thing is that it is necessary not to break the Law. Or do it secretly, without arousing suspicion.
You can also make that the law will be no complaints. Only energy suppliers at a loss.
If you have your own amount of energy, then this amount they will not sell you.
For the puppeteers of the consumer market, household energy independence is evil.
