Graham Gunderson open sourcing magnetic implosion transformer
Started by ramset, October 09, 2019, 02:09:54 PM
ramset
Thanks Grandma
Void
Hi ramset. Just FYI, regarding this video:
"Graham Gunderson Free Energy - Magnetic Implosion Transformer" - Sep 24, 2019
https://www.youtube.com/watch?v=aqxFC70wyM0
It is very hard to follow how a circuit setup like that is behaving and performing and exactly
how everything is being powered and measured when it consists of several circuit boards and different windings
on cores, etc., which the viewer does not have a clear schematic or at least a clear block connection diagram.
Unless someone has such details, it doesn't help much for understanding the setup for someone to point
to different points in the circuit and say they are measuring this voltage or that current, or such and such
type of a waveform or phase measurement, etc. So, unless someone knows much of the details of the circuit setup,
it might as well be a black box that he is pointing to.
For a person who does not know the schematic details, what stood out to me right away in that video at
0:22 in the video, is he points out he is using a DC power supply which is apparently supplying about 295V at about 0.08A,
(from the power supply's meters). That indicates that power supply is supplying a power of about 23.6 Watts.
If the output power is measured at around 10 Watts, then the input power of about 23.6 Watts (if correct) is much higher
than the output power, so it is not clear to me at all how this might be considered to be producing a COP > 1.
He also mentions one or two other DC power supplies supplying power to gate drivers in the setup.
That's about all I could get out of that video, as I am not familiar with anything this person has done
or any of the details of the circuit setup other than can be seen in the video.
All the best...
ramset
Hello Void
No doubt Graham flows thru this presentation easily and smoothly
With what does seem a tenuous confidence ,which is actually quite healthy and
Also professional (the scientist) ,it is after all impossible !!
He obviously knows this !
Makes him a great champion for this cause ,and he is such a likable guy to begin with !(in his video appearances to date ).
Hopefully a bit more detail will be forthcoming (schematic details?) ,quite certain there are many who will replicate this .
And of course there will be much discussion around the main gain mechanism !
Thanks for commenting!
Respectfully
Chet
Thanks Grandma
Void did not only a comment, Chet  !It is a statement and included the question : " magnetic implosion transformer"- technology substantial value. ?
input : 295 Volt     0,08 A.~ 23,6 VA ~ 23,6 Watt
output : 10 Watt
Assumed efficiency ratio :10/23,6 =  0,424 ~ 42,4%
A..device process efficiency
B. ONLY 10 Watt output for this transformer material mass. ? power-to-weight ratio. ?
Actually there are no reazons/arguments for titling Graham Gunderson " a great champion". !   :'(
alibaba-transformer with 10 Watt output and 42,5% efficiency  : 1 US$ gross-selling price fob factory. ! :P
Wake up, Chet. !
https://www.google.com/search?client=firefox-b-m&q=zpenergy+mark+goldes&oq=zpenergy+mark+goldes&aqs=heirloom-srp..
Mark Goldes sended me more then 10 years before by e-mai a pdf from the R&D of his team and one of this  "scientifical research" member : G.G.
ramset
 LancaIV
Yes your point is self evident, RE COP calculation protocols (the Nick Z mantra "Loop it" comes to mind.
Wall outlets and OU claims are always a fuzzy area.
   Your other point gives me pause ?(comments about ten year old info and persons unrelated to open sourcing this claim)??
  The "Champion" is an open source reference .
"If you want to change the world BE that change "
Live by example.
I would imagine Open Sourcing will include Enough info to
Replicate an anomoly.(or its not open sourcing)
LancaIV
I apologize if I have offended you somehow ?
You make many references lately in your posts to religion or beliefs ?
Non of us are free ... till every one of us are free .
Regardless "beliefs" ...which can devide us !
And open source has no "exception" clause!
yes 100% scientific method requires independent replication .
Chet K
Thanks Grandma
