GAP Magnet ray
Started by synchro1, October 27, 2019, 10:44:05 AM
synchro1
        GAP magnet Ray
A flat "neutralization coil" placed next to the face of the axial tube magnet (The one with the wire coil) would curtail five times it's own magnet force per masking pulse and amplify the BEMF. The North Pole of the pulse coil would draw the four magnet poles into it.The double advantage of this design is the retraction of the "Magnet ray" caused by the position of the coil's north pole behind the four crossed magnets. Not only would the coil shunt the axial field, but any portion of the ray projected by the four crossed magnets would be reversed by the attraction to the north pole from behind.Additionally, the strength of the magnet ray would be amplified by the pole reversal.
                                                  BEMF neo magnet amplification
The movement of the combined south poles would be in the same direction upon pole reversal through the coil.
The pole reversed amplified backspike would power the "Magnet Ray" from the D.C. pulse collapse. This EMP would pack a wallop.
synchro1
The wire coil and capacitor when connected by DMM electrodes reads a voltage when the "Magnet Ray" is interfered with. The inventor goes on to state that this coil can be pulsed and the pulse will oscillate the "Magnet Ray".
That coil can serve either role; Output or input.
A solenoid ferrite core masking coil, placed on the face of this magnet, would generate an amplified backspike due to the neodymium magnets. This increased power would amplify the strength of the "Magnet Ray" for an extra wallop EMP.
A Stiffler toroid bifilar style coil with bucking halve windings would generate output if focused on by the "Magnet Ray". Twin chiral "Magnet Rays" oscillated by crystal base timed transistors at 13.56 Mhz and aimed at the toroid coil from each side with opposite poles facing would generate even more output.
synchro1
Dr. Stiffler's "Static Field Moduation" demonstration:
https://www.youtube.com/watch?v=Iq3nww6Ban4
Bob Smith
Hey Synch
The patent reminds me of this story:
http://www.rexresearch.com/hurwich/hurwich.htm
Maybe you've solved the mystery of Hurwich's device.
Regards,
Bob
Bob Smith
IST (William) did some neat work with neos a number of years back, but kind of disappeared from the scene. Interesting stuff to consider/review:
https://www.youtube.com/channel/UCzHzN-rEcT1P790da30V71g
Bob
