Getting energy from asymmetry of the magnetic field experiment
Started by ayeaye, November 19, 2019, 11:10:15 AM
ayeaye
At that i didn't say that field irregularity is the only difference from the Coulomb model for magnets. There can be other differences, like inducing eddy currents, etc, that also are not in the Coulomb model. I only expressed my view that there cannot be overunity in the Coulomb model, and thus it is necessary to see what in the design differs from the Coulomb model, which of these differences can cause overunity, and how.
ayeaye
When the friction is equal to or greater than the force, then all one can measure in that way is force plus friction, by moving against the force. It would not be possible then to measure the force minus friction, as it then never moves in the opposite direction. To measure friction minus force in that case, one should pull with the scales in the opposite direction.
DavidWolff
Look why do you need a spinning bunch of magnets to generate electricity ?
you don't electrons are already spinning.
Your living in a programmed world that's out of date, who the hell wants a spinning giro in there pocket
when it could be self powered by a small plastic box you could screw up in the palm of your hand.
David
ayeaye
LancaIV, sorry, this is about research, the basic research, not making any permanent magnet motors.
DavidWolff, the magnetic forces are the simplest forces. Yes they are caused by electrons spinning, around the nucleus of an atom. Pretty much weird about that spinning.
