"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
Quote from: skywatcher on December 12, 2019, 01:32:02 PM
Measuring Self-Capacitance and Self-Resonant Frequency SRF of Inductors
https://www.youtube.com/watch?v=tjbK4LsOQRk
Nice find. Excellent video. A square wave generator and an osciilliscope. DR. Stifler was right though, you need a basic course in Scope Tronnics to run the equipment.
skywatcher
synchro1
That scope chop would disappear if you rewound the coil with magnet wire. Looks like you have the technique down, congratulations!. Good chance that one will work! Won't be long now!
synchro1
Build an Avramenko plug to test it. The plug can have two reversed LED's connected to the ends of the two reversed diodes; It will work one way or the other. Connect one end of the coil to the signal generator electrode set to the 13.52 Mhz with no power, with the ground wire free; Then see if an LED illuminates in the static field in proximity to the coil.
skywatcher
Would it be better to use a higher diameter for the coil, and less turns ?The highest Q is achieved by using only 1 turn of very thick copper (magnetic loop antenna).Those antennas have a very high Q.
Or maybe a flat coil with only a few windings, like Tesla used ?
