"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
"Intel Corp. unveiled a chip Monday meant to speed the development of commercially viable quantum computers. Code named "Horse Ridge," the cryogenic control chip is meant to control multiple quantum bits, or qubits, which must be maintained at a few degrees above absolute zero. Unlike traditional bits, which take on a value of either "0" or "1," qubits are considered to be able to exist in multiple states simultaneously in a superimposed quantum state, allowing for more complex calculations. So far, quantum computing has been demonstrated in experimental conditions".
This chip needs to be cooled down to nearly absolute zero to function. What advantage would a room temperature version supply?
Toolofcortex
Ok then, When you have time, I would like you to study it more carefully.
And then propose to me 3 coil designs.
Your designs will go into an automatic test bench.
synchro1
https://www.youtube.com/watch?v=qcT_D7yf6OY&list=PLO6FJVqlxatcX-8A4L7fhyUUlYJcdNziq&index=8&t=0s
14 diodes in same direction loop illuminating 12 LED's with no electrical input! The clip lead from his L-3 coil to the frequency generator electrode at 13.56 Mhz, and his ground electrode hanging free.
                                       There is no current going from the wire to the loop!
This power is flooding in from the static field surrounding it and circulating to it's ground discharge in the LED's. The capacitance resonance between the clip lead and the diode capacitance is opening a switch way for power from the surrounding infinite voltage from Space that circulates in the loop!
synchro1
https://www.youtube.com/watch?v=1y3AcIlBSX0&list=PLO6FJVqlxatcX-8A4L7fhyUUlYJcdNziq&index=11&t=0s
At 3:28 in this video, Dr. Stiffler states that his L-3 coil has an SRF (Self Resonating Frequency) of 13.6 Mhz.
Everyone of Dr. Stiffler's and Lidmotor's wireless power transfer videos features this 13.6 SRF single wire coil. That's all it really takes to do any or all of the experiments. You need a scope and a signal generator to build one. Good luck! He used to sell them, maybe find one on eBay?
synchro1
