"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
Quote from: skywatcher on December 12, 2019, 05:20:14 PM
I googled it, and there seem to be many different versions...
Take 2 diodes and one LED. Connect the two diodes end to end positive to negative. The two LED electrodes connect to the two remaining opposite pole diode wire ends. It won't work if the LED is connected the wrong way. 3 components 3 connections. The coupled wires from the diodes act as the antenna. Try 20 volts.
synchro1
Stiffler has 12 LED's burning at full brightness with a 14 diode ring. What would happen if we stacked 12,000 diode rings in a steamer trunk? Could we get a "Luxor Spotlight" of 144,000 LED's running off a 9 volt battery?
skywatcher
Quote from: synchro1 on December 12, 2019, 05:32:56 PM
Where is the receiver coil connected ?
Like here:  https://www.youtube.com/watch?v=PqsVQPLXi3E   if i interpret it correctly:  coil - diode - LEDs - diode - coil
synchro1
Quote from: skywatcher on December 12, 2019, 06:03:51 PM
It's a 3 second job to build the plug. The plug will act as the test receiver. Everyone thinks it's funny that this is causing you a problem. I built my first one 15 years ago. I was just as confused, and you'll be just as surprised as I was when you discover how simple it is.
You don't need a physical connection to the coil to generate electricity at this point.
