Wimshurst - let's clear this up
Started by nix85, February 18, 2020, 08:14:11 AM
nix85
How exactly does Wimshurst produce HV? I understand how charge induction happens on opposite discs. Charge is picked up from two pairs of oppositelly charged sectors (two on each side), but these two pairs alone surely don't produce HV.
Are all the sectors somehow adding up in voltage? That sure does NOT seem to be the case, at least i don't see how that would work.
Wikipedia says: https://en.wikipedia.org/wiki/Wimshurst_machine
"The available voltage gain can be understood by noting that the charge density on oppositely charged sectors, between the neutralizer bars, is nearly uniform across the sectors, and thus at low voltage, while the charge density on same charged sectors, approaching the collector combs, peaks near the sector edges, at a consequently high voltage relative to the opposite collector combs."
Wikipedia explanation that sharpness of the combs makes charge density on the adjecent sector higher and thus provides higher voltage makes sense, but i still don't see how many dozens of kilovolts would be generated that way, especially by a single sector pair.
I watched MIT video and this one too https://youtu.be/nA4aCd5qFWs?t=239
Anyone?
nix85
To clarify, as i understood later, it works similar to Van de Graaff generator, simultaneously adding and removing charge from opposite plates of a Leyden jar (cap).
antijon
As I understand it a static generator, like a van de graaff, operates by moving and depositing charge and functions as a current source. I'm not too familiar with a wimshurst, but I have a small van de graaff, and I know that the charge is able to build up because of the domed top. If you apply charge to the inside of a cup or sphere, it moves to the outside, so you can continue to add charges of lower potential as the outside develops a high potential.
Anyway, a current source has a near infinite internal resistance, unlike batteries or transformer windings, so the voltage increases to a value necessary to push current across a resistance. Theoretically a van de graaff could be used for free energy if it generated a high enough current because no matter the load resistance, as long as it's lower than the internal resistance, the voltage would continue to increase to match ohms law - IXR=E. For example, if a 120V bulb had a resistance of 120ohms, it would require 1A to light up. If you had a current source of 1A, you could power thousands of bulbs in series. What people don't realize is that with a current source power increases to match the load. The problem is making a static machine that generates a decent current.
nix85
Quote from: antijon on February 19, 2021, 02:09:34 PM
It works simply by electrostatic induction creating small voltages that charge the caps. Now this is a tricky part.
Indeed, adding charge to the center of a conductor allows to build up surface charge to any level cause the source does not "see" the built up charge.
And it does not have to be a dome
I long accepted this as solution for Wimshurst, but was lately skeptical cause Leyden jar is afterall a classical capacitor, not a VDG dome.
And we all know we can never charge a cap to 10V with 1V source.
But apparently this is bypassed in Wimshurst, exactly how no one explained clearly.
Max voltage obtainable by VDG is limited by volume of the sphere and insulation properties of surrounding medium, usually 450kV for 30cm sphere, but much more is achievable in closed ones.
Here is a good video about it https://www.youtube.com/watch?v=yaeITv9Ytko
Sadly author ignored my question below if adding external capacitance adds to max voltage, he clearly has no idea if it does.
As for the latter part of your post, i completely disagree, you are misinterpreting things. It is possible to extract energy from subtler energy forms ala Don Smith, but not just with electrostatic field, you need a dynamic component.
nix85
Is anyone gonna explain how Leyden Jars get charged to dozens or hundreds of kilovolts with tiny voltages on the rotating discs.
It has to be the adding charge to center of conductor principle as in VDG, but again, we are talking Leyden Jars, that is, a capacitor with two plates and a dielectric.
This is confusing cause, again, you cannot charge a cap above the source voltage.
I guess when you are charging a cap by electrostatic induction instead of direct application of voltage, you can charge it to any level even tho the source voltage is tiny.
But then again, electrostatic induction is direct application of voltage, i don't see a difference.
Hopefully someone will clear this up.
