10 Pcs Block Neodymium Magnets | Size: 20×20×3mm | N50 | Nickel(Ni-Cu-Ni)
Started by magnets, March 05, 2020, 04:13:53 AM
magnets
Block Size: 20x20x3mm,10 pcs per package.
Durable and Smooth: It is Coated with Ni+Cu+Ni Triple Layer Coating ,copper and nickel to give superior corrosion resistance and provide a smooth and clean finish and own shiny surface,look like stainless steel.They can be used for a long time.
These tiny magnets (20mm×20mm×3mm) hiteboard or bulletin board. Also can be used for crafting, jewelry, lockers,refrigerators, even creat DIY magnets.
No Scratch: Superior Corrosion Resistance and Smooth and clean finish surface, won't leave a single scratch on it.Do not worry it might scratch the fridge or your new table.
Pull Force :1.406kg ,Great for all Home, Office, Craft, Science Projects and Product Manufacturing application.
Specifications
Package Weight:   9.000000g
Length:
20mm
Width:   20mm
Height:   3mm
Material:   NdFeB
Plating:   Nickel(Ni-Cu-Ni)
Grade:   N50
Pull Force:   1.406kg
Tmax:   80℃
Shape:   Block
Number of objects in package:   100pcs
Tolerance:   ±0.1mm
