Coronavirus,uesfull information for fighting Virus [evolving from effected areas
Started by ramset, March 08, 2020, 08:56:50 AM
https://docserv.uni-duesseldorf.de/servlets/DerivateServlet/Derivate-39124/Dissertation%20L.%20Lindner.pdf
SARS1-Covid lethality average 10% of infected cases
                                 but        50% of infected cases with age >65
Question :                      these 50% deaths
        under controle -hospitalized/old peoples´s home-
        or alone in their homes ?
       the hospitals equipped with enough intensive treatment beds and ARDS-symptoms neutralizing equipment related peak patients numbers  ?
       If the risc for this age class is such high then only isolation is not enough but also an emergency call-phone near their body ( acting by hand,voice ! )
      "alexa"-similar  seniors health observation system
      https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.mobil-bleiben.de%2Fhilfsmittel%2Fnotrufsysteme%2Farten-von-notrufsystemen%2F
      and fast experienced/professional reaction-by-call capacity as ambulant  "emergency crew"
     https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.netdoktor.de%2Fkrankheiten%2Fblutvergiftung%2Fseptischer-schock%2F
     By eliminating the source of infection, doctors are trying to help the patient's body fight the infection.Nevertheless, about 60 percent of all patients die from this disease.
     The prognosis deteriorates because most patients had a weakened immune system before the septic shock.
ramset
It is my opinion this information could save lives.HCQ or Hydro[xy]chloroquine [ingredient in Lupus and Rheumatoid Arthritis and Malaria meds]]
can be converted to Aerosol form for inhaling  [much better for applying to areas
effected by Virus [respiratory system]this conversion will allow 200MG pill to treat more persons.
place 200MG pill into 100CC distilled water ,let dissolve while stirring... pour dissolved mixture thru a coffee filter into 2000CC distilled water... mix thoroughly ...load 10CC [approx] into a cold ultrasonic inhaler [NOT a thermal one] and breathe medication.
Important addendum HCQ is ineffective on persons deficient in ZINC "//  preferable zinc supplementation ROA is zinc acetate by inhalation 4 hours after the HCQ
// Zinc acetate ?  QuotePure zinc metal dissolved in pure acetic acid yields zinc acetate. The acetate ion is quite mild.
Ultrasonic Vaping is a good route of administration if it is diluted 1:10000 or more.
Thermal Vaping is not so good because its high temperature renders the chemicals more reactive and irritating and will decompose others such as the hydroxychloroquine. azithromycin and nicotianamine.
Also if medicines made into aerosol form ...dose size 500 times smaller than oral dosing
end quote
Thanks Grandma
e2matrix
Quote from: verpies on March 29, 2020, 06:45:37 PM
Dude! Concentrated Chlorine Dioxide is so toxic it will kill anything alive.
If you take it internally and you are stronger than the pathogen, then ClO2 will kill it and leave you alive ...albeit less healthy.
If it was true that it would leave you less healthy I have never noticed that.  Always felt better but given the choice of being less healthy or dead I'll take less healthy.  In my opinion you will be a lot more healthy without the coronavirus  ;)   The MMS is taken in extremely small amounts (1 drop initially in most cases) which are out of your system in a very short amount of time - which is why you have to take it every hour during the day.
ramset
I should add that Stefan had also mentioned this a few weeks back [I think it was the same stiff] however finding data to support a claim seems hard to find .
Thanks Grandma
Prophylaxe : hidrolinfa/hydro-Linfa et cet.
Such "systems" sold here in Portugal for 1000 Euros 2007 ,one "enerciencia"- associate built for 100 Euros the electronic parts and for 30 Euros the hipermarket massage-bath : were sold as " hydrolife",this all then in an " expensive" looking suit-case,okay : semi- hand work
www.hidrolinfa.pt it seems somebody is working like and by 2007 "strategy"
But for commercial production such devices for therapeutic use need  estatal institutions approvement  !
Buying approved electronic parts in a shop and doing the montage is actually - without tests and certification-illegal !
And not for "cosmetics institute" use ! This is a medical instrument  !
Rife + frequency : frequency + liquid : percutan body treatment
Not " enerciencia"- product,but from associates their " mylife"- Lda./Limited
