Real Free Energy from magnets !
Started by r2fpl, March 09, 2020, 09:21:54 AM
r2fpl
I did some tests with different magnets and they all rotate CCW. If the white thread were not twisted, the magnet would spin all the time. These are the features of Free Energy!
What these magnets do is similar to the Steven Mark TPU device! He mentioned that when the device is inverted it stops working. The same happens with magnets in the film.
https://www.youtube.com/watch?v=6VmNH1HtTOk
https://www.youtube.com/watch?v=Ol5cOSnOwPQ
https://www.youtube.com/watch?v=xTP4Abpy_W8
https://www.youtube.com/watch?v=IBaaFfbday0
Hello,good experiment and repeatable results potential  !
"Kreise"-l
You defined : all rotate CCW
Look for the Coriolis-force orientation in your region !? CW or CCW ?
Think about the potential energy in your " fiber" ,on which hangs the magnets  !
+ Meissner- effect ,now inverse : external  ?
r2fpl
I live on the north earth so for me the magnet turns CCW like a hurricane in the picture.
conradelektro
I did an experiment similar to the video https://www.youtube.com/watch?v=IBaaFfbday0 . But the bar (consisting of two powerful neodymium magnets stuck together) was mounted on a needle (serving as an axel, like the string in the video). This was then a compass which turned till "North of the bar" pointed towards "Magnetic South of the earth".
In the video https://www.youtube.com/watch?v=IBaaFfbday0 the bar (consisting of many magnets stuck together) should do the same, meaning, it should act like a compass. It should only spin some degrees till it is aligned with the magnetic field of the earth.
I can not believe that the bar spins without any outside help. I suspect the outside force comes from the string and the weight of the bar pulling on the string. The string is "woven" in a special way.
Greetings, Conrad
r2fpl
Quote from: conradelektro on March 09, 2020, 12:57:30 PM
Greetings, Conrad
I don't make fake movies!
...The string is "woven" in a special way.  ! NO SPECIAL ! normal !
please check it yourself if you don't believe it. It's very easy. You will be surprised, guarantees. If you can put a movie.
