Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
Raycathode
First I want to make it clear I clam no originality here and each published contributor
Reserves there own originality and copy right if any claimed respectively.
Hello Nelson, great to see you here, and yes some time ago your self Nelson published three videos on one of the threads on OU
which got me interested after watching Mr Preva videos it appeared to use a vertical ferrite re wound reactive (bucking coil) idea
Similar to Akula porch light circuit but simplified.
I tried replicating or more like finding out how it worked my biggest mistake was using square waves it didn't work.
It's all been a huge learning curve for me and I don't know every thing by any means in fact I now relatively nothing
by your standards its all about experimentation but knowing some threshold limits and tried and tested circuits
can help, as Mr Watson has shown here.
Other published reference to same type circuit idea were published by Dr Stiffer some years a go using a bifilar wound
mains filter circuit coil. Unfortunately he gave no component values or how the circuit actually worked. Or where the energy came from.
Main points to start experimenting with.
Keep winding impedance to a minimum
Found coil ratio 3 to 1 works best
Works well using a sine wave input
Works best with small incandescing filament bulbs rather than LEDs.
Note finding the common resonant freq can be end up being quite high
Raymondo
Raycathode
Quote from: lancaIV on April 04, 2020, 09:15:52 AM
What is a capacitor,physically ?
Off-topic ? On demand this poste will become deleted ! ::)
Hi there, unfortunatly I won't cover any of this what you ask as it's electro mechanical and those interested might find it difficult
to find your contrebution here.
Raymondo
nelsonrochaa
Quote from: WhatIsIt on April 04, 2020, 08:55:51 AM
Lately I been experimenting with bucking fields,
and have unusual effects.
I wont call it bucking coils anymore, but rather bucking fields.
There are differences in a matter how coils are wounded,
Some coils share electric field, some magnetic field, other share both,
creating different outcomes.
They all have one thing in common.
Bucking fields.
I am still in phase to determine differences, and for now had some progress in that direction.
Until then, there is not much to say.
At the end it really wont matter who was first, last or not involved at all.
We.are all making progress on our own way.
Hi WhatIsIt,
I will tend to agree with you about  how the coils are wounded , and maybe is problem that most experimenters find when make this type of experiments.
Depending how the coil are wounded , we could obtain different results .
People interested is such theme, maybe could put  there eyes in some of this documents I share . https://drive.google.com/open?id=0ByZY5hj0h0hXSlJFVkZMVGFXLUE
I have sure that will help improve the understand about the subject of "partnered coils" and help forward on  how should be wound the coils to able control the inductance of  other coil , acting like a current valve .
But to me the most important point is how to "blind" the input ; this means ; make use of the output without increase the main input current, if that is not achieved, well ..
Tesla talk about this aspect in some of their  literature, about blind one side of coil or in other words , cancel mutual inductance between coils  .
And Yes coils sometimes share electric field,  magnetic field, and not forget last one, the dielectric field :)
Best rewards
Nelson Rocha
nelsonrochaa
Quote from: Raycathode on April 04, 2020, 10:12:20 AM
Raymondo
Hi Ray, are you talking about exactly circuit ?  Could you point me please to the link of topic ? Thanks ;)
Best Rewards
Nelson Rocha
Raymondo
In rotational devices you see and feel kinetic forces,where are these kinetic forces in static devices ?
Or instead where " how converted ?"!  HEAT ? Over ambiental temperature process ?
1 stator/rotor coils couple to multiple stator/rotor couple
analog to 1 primary/secondary couple or multiple secondaries/primaries couple !
From a german EE-advicer his " Electropedia": 1 motor + 1 generator ~ 1 Capacitor
Primary ccw or cw winding ,secondary ccw or cw winding,.......
Is an ac output static inverter not also replaceable by ac- generator and ac-motor or dc motor couple :
      Transverter        Rotoverter
When rotoverter ~ Capacitor ?
analog :
When transverter ~ Capacitor ?
Be variable in thinking and physical experimental trials ( when you neutralize and when you accumulate EMF ?For what cores when air-coils possible ? )
Maths laws ! : Physics laws ?
When you are designing an electro- magnetic circuit scheme/schemata,are the positive and negative streams flows only the theoretical "educated orientations(without classical correction from wrong definition) and appears 1:1 = 1 perfectly in your physical experiment model ?
