Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
nelsonrochaa
Quote from: WhatIsIt on April 05, 2020, 10:29:25 AM
How did you blind input?
How much AC source spend if it has only one capacitor in circuit? (or one inductor?)
Basic knowledge.
Source does not see capacitor, zero consumption.
Let's say that bucking field coil has only 0,1 ohm resistance, zero inductance, high gauge copper.
If we connect serial with that capacitor zero inductance bucking field coil of 0,1 ohm,
will the consumption of source change a lot or near nothing?
Can you extract energy from bucking fields while source consumes nothing?
Source is blind in that case.
Now, we are coming to essence of my current research.
How different arrangement of bucking electrical field only,
bucking magnetic field and both bucking fields together combined gives different solutions to that situation.
For example, bifilar bucking field coil has strong electrical field because the way it is wound.
(Floyd Sweet, kill magnetic field, double electrical field).
What will happen?
Just one example.
"Can you extract energy from bucking fields while source consumes nothing?"
I didn't say exactly that. ☺  What i try explain , is different . When I say blind the input, I'm referring to this scenario.
Imagine this example ;
  the circuit have their input  connected to a power source , with a consume of 0.03A at 24v in idle mode , without any load at output . This output is full isolated from the input by a transformer .  When you short the output , or connect a load is expectable that the input current increase :) correct ?  This could be prevented in the way how the coils are winded make something like a valve . In fact in the my circuit example , if i connect a bipolar capacitor to charge in the output , the input current reduce to half of initial value , returning to its initial value as soon as the capacitor is full.
Displays a negative curve when charging the capacitor.
Or even you simply short the output , the current in input will reduce in same way .
I hope I was clearer this time because English is not my native language sorry .
Best rewards
Nelson Rocha
nelsonrochaa
Quote from: Raycathode on April 04, 2020, 01:45:04 PM
Hi Nelson you can find the posting here on this page https://overunity.com/12736/kapanadze-cousin-dally-free-energy/21240/
So is the circuit self oscillating only 2 or 3 wires toddle off unseen some where, you must perhaps use some sort of vfo with feed back locking
I would have thought and the other problem is the output isolation use of the mains filter and choke. Which is a little mind boggling
with out seeing how your advanced mind knowledge has sorted that one out  8) as i said I'm unprofessional but like experimenting on a
Educational level.
Regards Raymondo
Hi Rymondo
My head is no more the same :) now i'm remember that post  :) .
Yes that circuit work in auto-resonance mode without and input from outside . I need to give a "kick"  to circuit start oscillating , after that the tank circuit give the needed feedback to the circuit continue oscillating .
And yes the isolation is made with a choke . Is 1:1 choke , so in the output is full isolated. from output . but could be other type of coil or transformer.
Why your show interest in that circuit ?  ask me if you have any doubt .
Best rewards
Nelson Rocha
AlienGrey
Nelson hi yes it was last year some time I was interested in that circuit your discussing now
It does look rather like the circuit IVO has been using that's obviously yours.
I think it's brilliant but if as your saying it can self oscillate that's even better any way I cant really see you giving it away or selling
The know how to the loan armature any time soon a pity really as it would perhaps be a sauce of useful light around the house ect.
Any way nice to see you on here again
AG
nelsonrochaa
Quote from: AlienGrey on April 05, 2020, 07:03:34 PM
AG
Hi AG ,
Hope you  goes well .
I really don't want talk about that person ...  I just decided to forget that name IV... .
changing subject ....
This small circuit  is not  tested is only a model and a idea  of something that could be scaled, but I'm not claim nothing :) like OU ok ?
To I claim something I need to make other measures and tests, but in this moment  I'm a bit limited in equipment .
I have a scope current probe but don't have at moment scope :( so I made some current measure with my precision multimeter Rigoli but is everything very crude;
I left this new videos with more detail of some aspects of circuit .
Sorry by my poor english in the videos :) but is better then no voice :) and I think is more easy to follow the circuit.
It could be seen that input current decrease when the output is shorted  , and apparently the output current is higher then the input . I put the small filament bulbs in series on the input and output to be more easy visualize the current .
The output is full isolated from input, and is rectified from ac to dc to be more accurate measure   .
Vídeo 1 https://photos.app.goo.gl/Qy4Wpo7rzfyKfdQ79
Video 2 https://photos.app.goo.gl/brsytsQWBsTwbxL3A
Video 3 https://photos.app.goo.gl/Gz1Z6hwcSzjMGEAEA
Best rewards
Nelson Rocha
As experimenter me would ever interest :
relationship : cw: cw  cw: ccw   ccw:cw  ccw:ccw
current form : direct - alternant - pulsed
coil input to coil output :  only the coils operating differences
coils - partnered,combined double,winding- input and coils output : only this coils effect operative differences
Coil  physical turning numbers
partnered coils physical  turning numbers
coils physical distance
Operation process :
stimulare,turn on ~ accelerare F = ma
to electro-magnetic                    F = BIL
W = Work= physical turning numbers x static-coil-rotative Ampere- turns
W=                                    winding turns x turn windings
Wind  to winden = turning ,rotating
Ampere- rotation or Ampere-turns = CURRENT
currere = german laufen infinitive as Nomen Lauf here in Physik KREISLAUF = circuit,cycle,rotation
           Hertzian Kreislauf = Hertzian Schwingung
rotation from rotare means Drehen or (An)Turnen as same vertere also as nomen verter or con-/in- verter
         KREISLAUF = CURRICULUM
Are here Physics-language An-alphabets in work ? And trial ?
in rotor as coil configuration /partnered coils configuration
and stator as coil configuration/ as partnered coils configuration
as " transformer / transverter" configuration
with different "geometric" poles numbers
each input as primary and each ss secondary,with different " virtual static poles"numbers
ambient temperature tests / fridge installation 5°-10° C / freezer installation -20°  - -10° C
