Nelson Rocha Workbench
Started by hartiberlin, April 30, 2020, 02:57:05 PM
voltaicfractal
Quote from: nelsonrochaa on May 30, 2020, 12:48:21 PMThe houses don't start with a roof, but on the ground because the logic of gravity defines it in our common sense :)
I am not concerned that some of you are not interested in this topic just because I did not announce or make a claim that I would build an OU system.
I am sure that many people will get involved, without asking for anything in return, and only by the route they can follow throughout the construction process.
In the end, we will have the chance to check whether it was worth it or not, but it will certainly be more productive, than to disdain and simply stand with arms crossed, behind a computer, ruminating on personal frustrations.
This seems like the best approach to me. Focusing on what we can learn. So much of what I thought I knew from reading a book or watching a video had to be replaced when I was confronted with an observation that contradicted the way I had understood things to be. Even among the brilliant minds of these forums where non-conforming ideas are explored there is a great many who believe they already have all the answers. They do not (no one does). If we work together we can find out the answer to questions the great minds have yet to ask.
EMJunkie
Quote from: nelsonrochaa on June 01, 2020, 05:16:37 PM
Hi Chris, hope you goes well,
In Your Opinion; Does the Energy come from inside the Insulated Copper Wire? But only when the right conditions are met for the Charge to flow?
Chris , in my opinion  the energy cannot be contained in the wire, inside or outside ; the material of wire it should be liable to be a path to charges (electron flow and for these movements occur, like cooper meets these conditions.
Therefore, it would not be correct in my perspective to establish that the wire contains energy, but rather behaves as a medium for energy manifest itself, in this case  when EMF is applied in the wire or by variation of magnetic field  by a magnet for example .
The electron charges in wire  acquired energy from outside to react and flow, but without this external energy should a current flow in the wire ? No .
This is my perspective .
Best Rewards
Nelson Rocha
Hey Nelson, Yes good perspective!
At an Electron level, all Energy is contained int eh wire then? But Sub Electron Level, the Energy is universal, I think we agree on this perspective.
Thanks Nelson! Everyone has their opinion, but very little of that opinion matches working machines.
Best wishes, stay safe and well My Friend,
   Chris Sykes
Mr.Sykes,good morning !
Are you,Mr.Sykes= MrRocha
I think not ,two different individuals !
"energy is matter " ergo rezipok"matter is energy" : energy is not only defined by objective  matter-difference !
Does energy also mutate like matter ? Why not ,it is by "particle and wave"-duality analog to treat !
When becomes "it= energy"  from the stadium-terminus definition ,geral/specific(individal) un-/conditionzed , 1st stage "pressure" to to 2nd stage "force" to the 3rd physical stadium-terminus "energy" ?
How many "energy"-stages are physical ,in geral,accepted 2020,internal different or only dependent from external
observant position ?The subect observant his own speed/veocity in relation to the external " observed "energy-object or" object energy" them speed/velocity ?
Context(e) dependence : " energy is not destroyable" real or wrong hypothesis ?
Physical arguments by reproduceable facts
Realspace versus Hyperspace : ex-/in-cluded "time dilatation" = "stroying conditioning"
Argumenting by/with same Raum-Zeit/Space-Time-Matrix ? Not possible cause there is ever changement !
Btw " religions" are Time-Lord philosophies,space independent,velocity and speed independent
         It is how It is,without question "why"
        "why"-resolvement is philosophy/philology neutral physics branch
You,Mr.Sykes,are inside the Heisenberg-Dilemma  8) :)
Is before the evolution stage,by given freedom(e)-degrees,soon a first stage " the formation" as destination,physical responses and not "philological/pilosophical" :
minimum 4d pre-destination,by planet Earth as Solarsystem Sub-membership,the Solarsystem as Galaxy-system "Milky Way" - Sub-membership
How much decisions with total/zero "freedom-degree(s)!? Axiomatik !
"Was zuerst ,what first ? Henne or Ei/egg"- question response Dilemma !
IM-/EX-/DE-PORTANCE of "?" and "!"   to be a " good/ bad" guy/guide ? ::)
SincerelyOCWL
ramset
Just a note:I believe some much needed equipment is on its way to Nelson...spoke with a researcher today who had assisted with a better vendor [quicker and reliable ... with product support]
will hopefully touch base tomorrow with Nelson just to be sure things go smoothly
IMO persons who share their work open source ...require all the support we can muster...this way those who cannot do the experiments can help those who can .and all is transparent and shared..
much gratitude and respect  Chet K
Thanks Grandma
NickZ
   Ramset:   Thanks for the info. I hope that NELSON gets what he needs to continue soon.I too received a new scope given to me by a member of this forum. I wish that I could remember his name now, to give him my gratitude, once again.
