floor sweepings dust bin
Started by Floor, May 21, 2020, 03:55:06 PM
Willy
Online Willy
    Moderator
    Full Member
        View Profile Email Personal Message (Online)
Re: More clairifaction of floors Twist Drive
« Reply #38 on: May 14, 2023, 02:30:02 PM »
    Modify
    Remove
    Split Topic
I have been thinking in terms of the electrical output being
ran through optical isolaters / couplers.
An electric to light then back to electric conversion.
No load matching would then be needed for the final electrical output ?
Added
   Load matching may not be the right choice of words, but there would be no feed back
to the source.  Unless the solar cells emited light and the LEDs collected it.
Modify message
« Last Edit: May 15, 2023, 11:59:41 AM by Willy »
Willy
Quote from: citfta on May 14, 2023, 08:43:09 AM
Optical couplers  can only transfer a signal, not power.  There has to be a separate power source on the output side of the coupler.
Willy
Quote from: Willy on May 14, 2023, 02:30:47 PM
Thanks for the correction CITFTA.
Then a new device ?
A light passage coupling of leds with photo cells device.
Each optimized for the specific light frequency which can maximize
the effenciency of the energy transmission.
Willy
Quote from: lancaIV on May 14, 2023, 03:44:45 PM
https://www.tutorialspoint.com/signals-and-systems-energy-and-power-signals
https://learn.digilentinc.com/Documents/130
Both energy and power signals are mutually exclusive, i.e., no signal can be both power signal and energy signal.
A signal is neither energy nor power signal if both energy and power of the signal are equal to infinity.
All practical signals have finite energy; thus they are energy signals.
In practice, the physical generation of power signal is impossible since its requires infinite duration and infinite energy.
All finite duration signals of finite amplitude are energy signals.
Sum of an energy signal and power signal is a power signal.
A signal whose amplitude is constant over infinite duration is a power signal.
The energy of a signal is not affected by the time shifting and time inversion. It is only affected by the time scaling.
particle-wave (which represents power/which energy) uncertainity
No conditioning : no rule
https://en.wikipedia.org/wiki/Black_silicon
Cooper pair  https://en.wikipedia.org/wiki/Cooper_pair  https://en.wikipedia.org/wiki/Valence_electron
Recombination- actio/reactio - time window
https://pv-manufacturing.org/metrology/recombination-processes/
https://en.wikipedia.org/wiki/Metamaterial
(solution : Femto-diode-array  !?) alternatively http://www.novasolix.com/
and   thermo-photo cells or thermionic cells thermo-phono cells
