seg generator. here is the correct design for the rollers
Started by superhero, June 13, 2020, 09:19:13 PM
superhero
To all of you geek community I figured out the free energy design for the rollers here you go and you're welcome
   Please view attached design.
Keep in mind the following:
1-rollers must be diametrically magnetized.
2- use fractal spiral magnetization similar to crop circle attached.   That means the magnetization Value for each roller is different.   Weakest at the very top and bottom rollers and increases to the center.
3-  The center core magnet will affect each roller level differently, & to balance the values you must use fractal spiral magnetization  At each level of rollers.
4-  use counter clockwise spinning of the rollers to use the Earth counterclockwise magnetic field to aid and assist if you're located in the northern hemisphere.
5- the north in the sketch is the earth magnetic north .  I think south in regular magnets are North geographically.   Not sure.  100%
6- just make sure the attraction level for each roller to core are equal in every level after utilizing fractal magnetization.
7- level 4 and 5 are the same exact value. (if 8 rollers total)
8- the forces moving the rollers around the core are the Earth magnetic field, and the core magnet
Good luck
Rabi
Let's save our planet
Good luck
Rabi
For any of you not familiar with SEG here's a video link
https://youtu.be/CJ_QdrZC6VI
citfta
Please delete your drawings and resize them to the recommended size for this forum and then repost them.[size=78%] [/size]You only have a few hours to do that before your post gets locked.  I use FPC or Free Photo Converter to resize my photos before posting here.  The size you have now makes if almost impossible to even see what you have posted.
Respectfully,
Carroll
ayeaye
Quote from: citfta on June 14, 2020, 07:08:31 AM
Citfta, why are you telling that, you are not moderator here.
About decreasing the size of the drawings, i fully agree,
they are dmn annoying. I cannot read posts with pictures
that size, because lines become so long that it's difficult to
read to the end of them. Almost no one has read this thread
though anyway.
citfta
Quote from: ayeaye on June 14, 2020, 07:36:45 AM
though anyway.
EYEEYE,
I posted it for the same reasons you have in your post which you deleted from my quote.  What is your problem?
And the thread has only been read a few times because he just started it.  DUH
Carroll
citfta
Hi superhero,
Thanks for resizing your photos.  Now I can see what your idea is.
Have you had a chance to build anything based on your idea?
Carroll
