highway magnets charging hybrid batteries through electromagnetic induction
Started by jbm, December 29, 2006, 10:21:29 PM
jbm
Hi all,
   I'm no expert in physics, but I had an idea:
   If permanent magnets were embedded in the pavement of roads, it should be possible, at last in principle, to recharge hybrid batteries as cars drive over the magnets - using electromagentic induction.
   My first question is: does the generated EMF have a "push back" force that works against the car?  For example, if you pass a magnet through a coil of wire with your hand, do you have to push a little harder than if the wire wasn't there?  If so, what is the size of the "push-back" force with respect to the generated EMF?
   My physics is pretty poor, so I need help with this one.
   Even if it is a viable idea, the cost of putting the magnets in the pavement and adding the necessary electronics to hybrid cars would probably be tremendous.  Of course, the environmental and national security consequences of doing nothing is also tremendous.
Joe
shipto
the first problem I see in that idea is that you would get piles of junk gathered around the magnets, bits of rust etc.
Paul-R
I think that the dreaded Lenz's Law will rear its head.
But, if instead of passive magnets, you put an elctromagnetic
coil, and induce an EMF in a coil in the vehicle, then it will
work - but no OU pretentions. Simply a good way to recharge
batteries on the move at the expensive of whoever is
putting the power into the coils in the road. Possibly roadside
windmills.
Paul.
ring_theory
For electromagnetic induction it is better to put the field through the center of the induction coil. This is the problem with induction.
How to drive multiple magnetic flux fields through induction coils cyclic?
The answer is simple A toroid multipole armature. see fully baked innovation.
FR 2239802,page 1 : Laplace Law
Happy new year
                      dL
