Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
this is ou. the torus can be very simply assembled from smaller magnets of any shape. 3d eggcrate. 2 balanced siamese disc traveler projectiles attached to an internal circumferential ceramic ring bearing would go hypersonic evacuated. axle arms can join in the center fitted through a slit around the inside of the torus to leverage mechanical power output.
synchro1
We can "Orbo" wrap the projectile disc and install commutator electrodes along the inside rail to neutralize pulse the traveller through the gate from an external power source. A second one can balance the rotor and use the same commutator rail. An axle can connect the discs to a central hub. The arms can pass through a slot on the inside perimeter of the Torus. This may output useable horsepower!
synchro1
                   Orbital gear outside the radius and diametric poles outside the double twins.
An invisible wall appears at 180 degrees on the "V" gate in this video. Two traveller discs would cause a second stop. Splitting the toroid can help overcome this problem.
https://www.youtube.com/watch?v=SyQ5--E6LAk&list=TLPQMTkwNzIwMjDi8PZb2YbwQQ&index=2
A second rotor disc will make the rotor boing at 180. One disc would need a dead weight to balance the arm. These sections would act like twin magnet cannons. Very powerful kick.
synchro1
This axial polarized ring sawed in half then coil wrapped and rejoined with one side reversed. The "Orbo Piston". These polarities are the same as the Kundel stator. The diametric is the shell. The coil ring would press firmly into a slot.
synchro1
parallel diametric smot track.2 trans twice the floor force.
