Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
What would happen if you screwed a large ring down on multiple radial spoke stacks of refrigerator magnets? Would the compression force increase on the ring?
"Unlike most conventional magnets that have distinct north and south poles, flat refrigerator magnets are magnetized during manufacture with alternating north and south poles on the refrigerator side".
synchro1
hexagonal spiral monopole magnets from uroborus; perfect for the diametric arrangement.
synchro1
This configuration should deliver 2x's the floor force. Uroboros has all his magnets facing the same direction. The twin semi disc would fix rigidly to a through slot axle and connect to a central bearing.[below]
Orbo wrapping the traveller disc would allow it to pass through the twice force torque gate with the same efficiency as one.
synchro1
The commutator rails are on the inside lips of the slot. The axle bearing holds the traveller disc rigid. The brushes are on the neck of the connecting arm. The power source is outside the torus. The backspike from the gap coil would be awesome. A recovery diode can charge a storage capacitor from a third commuter attached to the positive brush and running through the axle to a contact. In parallel with the battery, this should run at 100 percent; That leaves all the work the traveler does as gain.
synchro1
A helical blade would work as a powerful industrial fan with zero operating cost; or, it could spin a windmill alternator on a still day. Output of this motor generator would be directly proportional to it's total magnet strength in Gauss. the pulse looped to capacitor.
