Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
Wires can run through the axle from the masking wrapped driver coil to brushes and a pulse coil.
The coil flips the driver disc magnet by pulsing a tiny diametric tube on the axle shaft, and simultaneously energizes the masking coil. A diametric of reversed polarity is positioned at the throw limit.
The energy requirements to power this reciprocator would be the same for any size.
synchro1
we can both kick and mask the traveller with separate wraps; we need to collect the backspike to eliminate the Lenz drag. a spline would clear and re-enter 2 slots. a collar would need to be machined at the end of the tube to spin the traveller spline.
synchro1
The axle is removed, and two commutator electrodes are positioned at the ends of the slotted tube. We have two designs: The rotary and reciprocal; The advantage of the reciprocator is the coil wrap. The commutator electrodes charge both the masking coil and the rotation coils in the outer collar space. The BEMF from the magnet core neutralization coil would stay even regardless of the size of the magnet stator and traveller. When the coil interrupts the current, the masking field collapses and the traveller spontaneously accelerates down the tube.
A 3D egg crate for multipal cubes and interior tube with slots need to be designed. The recovery diode and storage capacitor in parallel with the battery equal Unity for input alone regardless of scale.
There's a ferrite attractor at the end to fasten the contacts. This area of the traveller coil needs to be partially free of masking strength.
synchro1
The ring traveller wrap needs two tiny axial coils at the perimeter to flip it. The toroid masking field is at 90 degrees. The traveller can ride in grooves on ball bearings that double as rolling commutator contacts. The balls can run on the inside of the commutator arc rails. The slot keys can be made from resilient teflon. The top commutator arc ends short and interrupts the current when the balls align with the grooves. The ball looses contact with the start arc; The current's interrupted, and the traveller magnet fires off like a bullet.
synchro1
Copying Kundel's outrigger design, we can flip neutralized rectangular magnets with parallel tracks:
