Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
sm0ky2
If you take a stronger magnet and force it on the stack in opposition
you can align it just before the point of total envelopment
Such that as the stack approaches the active magnet, the additional compression
causes a pole reversal, and a flux of exponential magnitude
synchro1
Quote from: sm0ky2 on August 20, 2020, 08:13:35 PM
I see your point. Have you seen the pole reversal effect of pushing a magnetic ferrite rod through the center hole in a ring magnet on a diametric spinner?
https://www.youtube.com/watch?v=GeeivXPsuro
An Adam's resonance oscillation with a 1/16" throw could power a diametric rotor reversing the field of a ring magnet with a tiny ferrite plug solenoid coil as in the above video!
synchro1
The small movement of the ferrite rod inside the core of the ring magnet reverses the field of the ring magnet and amplifies the coil's magnetic field force many times: The ferrite rod is drawn to the top of the ring by magnetic attraction, and the coil attracts it inward slightly as a solenoid. There is a Neo disc magnet attached to the bottom of the ferrite rod in opposition to the face pole of the ring!
sm0ky2
Quote from: synchro1 on August 21, 2020, 10:47:56 AM
Howard Johnson described this effect.
This is the effect that powered the Lockheed Martin magnetic jet engine.
