Theoretical , experimental progress on Aether theory, Tesla’s longitudinal waves
Started by ramset, September 05, 2020, 12:29:27 PM
ramset
lamare shared this at Aaron's Forum
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/500167-theoretical-and-experimental-progress-on-aether-theory-and-tesla-s-longitudinal-waves
Quote Hi guys,
First of all wanted to share some recent experimental results into superluminal FTL signals aka Tesla's longitudinal wave. I finally managed to repeat Wheatstone's 1834 experiment with modern equipment by working with a mercury wetted relay in order to obtain extremely fast rise-times and an active, capacitively coupled probe. Turned out Dr. Steffen Kuehn also managed to transmit information trough a coaxial line with a velocity much faster than light, so now we have two independent measurements of superluminal signals:
https://www.researchgate.net/post/Di...ativity_theory[/color]
However, that does not yet gives us an antenna for tansmitting / receiving these longitudinal waves through the air rather than through the earth as Tesla did with is TMT. Biggest problem towards achieving that goal is to solve the problem of how to couple a coaxial feed into a longitudinal wave propagating along an antenna wire.
When I experimented with a 4 turn coil wound around a piece of coax cable, in parallel with a trimmer capacitor, I was able to find a "hot spot", whereby the resonances in the system (the dips on the screen) would suddenly just shift, as if there were two possible wave propagation modes along the dipole and it would shift between the two. I made a screen capture of the measurement and underneath the video there is a link to a few photographs of this rather simple setup:
https://youtu.be/CFEsklvbP-k[/color]
The sound is very bad, but at around 2:30 in the video you can see what happened. I believe this is the trick to be able to couple a HF signal from a coaxial feed into either a longitudinal mode or a normal EM mode wave propagating along a piece of wire. Interesting and significant detail is that the 4 turn coil was measured to have a negative reactance at the frequencies I was working (70 cm band), which means the coil actually behaves like a capacitor on this frequency band, thus enabling capacitive coupling rather than inductive coupling, even though we are working with a coil.
Finally, I have been working on a new physics aether theory for years now and have now mathematically proven that Maxwell's equations are incorrect, because they violate the fundamental theorem of vector calculus, the Helmholtz decomposition. Turns out Maxwell entangled a model for the medium, the aether, with the macroscopic Faraday law, thus destroying the fundamental symmetry dictated by the Helmholtz decompositon. And this not only led to Einstein's relativity, but also to the vector and scalar potential fields having not been uniquely defined. This left a hole upon which pretty much the complete "standard model" rests upon, as it is a "gauge theory":
https://www.researchgate.net/publica...39;s_Equations[/color]
Even though there are still some errors in this paper, I believe this theory will sooner or later lead to a revolution in physics, whereby it shall be recognized that Tesla was right after all:
"According to the relativists, space has a tendency to curvature owing to an inherent property or presence of celestial bodies. Granting a semblance of reality to this fantastic idea, it is still self-contradictory. Every action is accompanied by an equivalent reactionand the effects of the latter are directly opposite to those of the former. Supposing that the bodies act upon the surrounding space causing curvature of the same, it appears to my simple mind that the curved spaces must react on the bodies and, producing the opposite effects, straighten out the curves. Since action and reaction are coexistent, it follows that the supposed curvature of space is entirely impossible.
But even if it existed it would not explain the motions of the bodies as observed. Only the existence of a field of force can account for them and its assumption dispenses with space curvature. All literature on this subject is futile and destined to oblivion. So are also all attempts to explain the workings of the universe without recognizing the existence of the ether and the indispensable function it plays in the phenomena."
You may also be interested in a more intuitive background article I wrore a couple of years ago, wherein I investigated where all of our theories come from and concluded we needed to take a close look at Maxwell's equations:
http://www.tuks.nl/wiki/index.php/Ma...FabricOfNature[/color]
https://www.youtube.com/watch?time_continue=2&v=CFEsklvbP-k&feature=emb_title
end quote
Thanks Grandma
ramset
Thanks Grandma
