RANT CAFFE ASYLUM
Started by WhatIsIt, September 06, 2020, 10:09:59 PM
WhatIsIt
Fact 1
Chrys Sykes and CaptainLoz are same person.
Chris is using alt's to fuel faith of his members and gain new ones.
Fact2
Bucking coils can be reproduced only on Chris web site.
To achieve that person must become member of Chris web site.
Fact3
Chris members gladly pays donations to feel respected on Chris web site,
because they were laughed or rejected on other forums.
Fact4
Chris is psychopath who dont care for anyone.
Chris enjoys to be "great lider" and collecting money from his members,
to keep running that role.
If some of his members change opinion, been called troll and banned.
Real questions are not allowed there.
Dont forget about donate button and become part of SOMETHING better,
whatever that "something" is.
I take an electric drive air/water  heat pump and get an average C.O.P. about 4 !
But based by german EE/PE mix unit (primary energy per electricity unit : older 2,6 to now 1,8) this means :
4/2,8 = C.O.P. 1,42 and 4/1,8 = C.O.P 2,2
          machine absorption work heat output ,BTU, versus primary energy input coefficient !
Now I converse these BTU by low-temperature heat converter with 50% efficiency for this energy level and coupled to this converter a generator with 90% average to electric energy efficiency I get :
4 x 0,5 x 0,9 = BTU to electric energy conversion 1,8     divided        " newer" 1,8 primary energy drive consume =
So
                         Grid  electric to electric total conversion efficiency 100% or C.O.P.: 1
But : when I go off-grid and give from the generator electric output the heat pump electric motor consume then I have an off-grid closed circuit efficiency : C.O.P. ( 4 x 0,5 x 0,9 ) - 1 = ≥ 1
Physical electric motor improvement : + 100%  torque/rpm per Watt
Physical electric generator improvement : + 100 % ( Watt per RPM/force)
Technical closed cycle improvement : 400% possible or 4 times better results
To motor input or/and generator output electric dynamic generator :
" or "= up to 4 x 10 times better results  and by condition " and" : up to 4 x 10 x 10 better results
   Electric to electric C.O.P. up to ≥ 400 cascade ,step I,array possibility
The C.O.P. = 4 is right,but also the C.O.P.= 1 is right ! It depends from the definition !
No fake,no lie : point of view !
Sincerely
p.s. : question in bucking coils arrangements : Q-factor,energy storage potential !?
         this compact pulsed in 10% duty factor/cycle !
WhatIsIt
What Chris is doing is called:
On Chris web site - friendship and sharing openly.
In real world - SCAM.
stivep
Dear Friends :
what was first:  motivation or emotion?
Primarily Emotions is what  makes some individuals to act in hope to progress.
reason1:
The need to be important and known and possibly make  some money on it.
example:
https://www.youtube.com/watch?v=yhuBlxLktKE&t=335s
in this video
the value is  very amateurish,the mistakes are  noticeable the knowledge is  very basic
But he was really trying to do his best.. and that is very good ,  I'm for it. Thank You.
However  to build  something you need good Concrete Foundation:
and naming his video channel :
Aboveunity and hyiq Research Channel was a big mistake.
there is no above-unity and hyiq earned bad reputation.
__________________________________
reason2: Money paid by dictator based regimes such in Russia.
              Russian government: dictator being 21 years as president fears that FE  collapses his empire and sends him to -
                The Hague, Netherlands : Permanent Court of Arbitration, a permanent
                superseded by the International Court of Justice International Court of Justice (since 1945)
                for crimes against humanity,
________________
If we assume that all of you are somehow having  basic interest in electronics/ electricity
and I give you incentive
than
add.reason.1 -  yes some  individuals  that are absolutely,  dull may become brilliant in given field .
factors: time  and money.
If I give you deal:
add.reason.2
- memorize 3 pages of text for 200 dollars + additional 100 dollars if  you pass simple test from that 3 pages
  and than you are allowed  to
  memorize another  3 pages of text for another 200 dollars + additional 100 dollars if  you pass simple test
Result : after the week you will do 3 pages per hour instead of 3 pages per day..
base for  my conclusion from above is : consequence. a number, quantity, or value obtained by solving a mathematical problem
._____________________
or If  Some Russian troll factory  pays you for  placing nonsense here
than they pay less but money  is easier.
but than I may do everything to throw you out from here.
That is the difference between e.g a Russian troll and curious motivated  thinker here.
Wesley
https://en.wikipedia.org/wiki/List_of_countries_by_English-speaking_population
captainloz
Hi Guys,
Some of the comments here are pretty vicious. Just so you know I have been a member here for many years. The reason I joined Chris's forum was because he actually helps you figure stuff out. I am no expert but am learning more and more every day, thanks to Chris and other members. I have been very transparent with all my videos. I have made a lot of mistakes that people point out because I leave the comments on on all my videos. I'm commenting here because Itsu asked me to comment about the bulbs I'm using in my latest experiment.  They're just 14Volt .2A radio shack screw in bulbs. I got them at a clearance sale when they were liquidating. Also a MR16 7.5 watt LED Bulb.  I don't know if the bulbs are consuming all the power shown across the resistor, I just know if you take the measurements as you normally would it's showing a gain.  I am not trying to mislead anyone. I'm just sharing my real time results.  Take it or leave it.
And just to be very clear I am not Chris! That's ridiculous.
If you are interested in my latest experiment follow the thread at aboveunity.com. Or just watch my latest videos, I'm not hiding anything.  Sorry guys, I'm not going to be doing two threads I just don't have the time.
Cheers,
Loz
Quote from: picowatt on September 22, 2020, 03:19:53 AM
EMJ,
If you believe the bulbs CaptainLoz used in his video and
referred to as "flashlight" bulbs can handle 15 watts each,
then he can easily put the naysayers to rest by putting the two
lamps in series across his  DC supply and show the world
how they can dissipate a total of 30 watts.
As for Brad's gizmo, your rewrite of history is way off base and
the truth is available in threads on this site for all to see.  Poynt99, TK, MarkE,
myself and others actually helped him solidify his measurements
and were becoming convinced he was on to something until
Brad himself unexpectedly pulled the MIB/Mylow card.  This
forum has not been the same since.
So now, who knows...
But that was good for a change of subject anyway...
PW
ADDED:
The bulbs in the video appear to have the E10 screw base. The
bulb you posted an image of has a larger E14 base.
