Three Layer Disk Magnetic Motor
Started by Lunkster, September 15, 2020, 01:12:17 AM
Lunkster
This motor design uses torque from three permanent magnets to one electromagnet during the function of this motor design.  The electromagnets operate at a 25% duty cycle.  The rotor is divided up into different segments of travel because the stator assemblies are being reconfigured as the rotor is rotating in the motor.  The rotor will interact with magnets on the stator while the power is off to all of the electromagnets.  After that movement is done, then every other electromagnet is turned on for the next segment of travel again.  THe power to all the electromagnets are turned off again.  The permanent magnet in the rotor now interacts with the stator permanent magnet to move the rotor another segment of travel.  After the rotor has moved another segment of travel, the electromagnets that had been off during the second segment of travel are now turned on to move another segment of travel.  So now the rotor moves through the forth segment of travel.  This sequence is repeated over and over again.
So this motor was designed to be operated with a TANK circuit or other highly efficient circuit that reuses the back EMF created in the electromagnets.   THe electromagnets need to be closer to the rotor magnets than the stator permanent magnets, so that when the power is applied to the electromagnets, the force from them has greater attraction to the rotor magnets than the permanent magnets on the stator assemblies.
Now having torque at a ratio of three to one from permanent magnets along with electrical circuits that can recover some of the electrical energy used in the electromagnets may be over 100 percent efficient.  But without the motor and the electrical circuit built and tested, we may never know.  At my age and limited abilities and resources, I most likely will not be building them.  THat is why they are free to the world to have them.
The Lunkster
stiplanet
hello thanks for the sharing  I want to try to build it. if you will assist me in the construction.
best regard
Lunkster
Quote from: stiplanet on September 15, 2020, 03:30:38 PM
best regard
That would be great.  How can I assist you in the construction?
I started to build this motor several years ago using a wood frame.  Big mistake because the wood warped.
I was building the stator in two disk's instead of one so that the electromagnets were on one disk and the permanent magnets were on the other disk.  In this way I could adjust the distance the electromagnets were from the rotor assembly separate from the distance of the permanent magnets of the stator assembly to the rotor magnets.  This way I would be able to optimize the design.  I was going to use air core electromagnets so that the core material would not be attracted to the permanent magnets during the operation of the motor.
I gave Apparently.com a PDF copy of revision one of my book "A free gift that may be over unity or free energy to the world"  More details about the motor is in that book.  I am now up to rev 3 in the book because I added a lot of things since rev. one.  Five times every three months, I am able to give away free kindle versions of the book if you are interested.  Otherwise I will be glad to help out anyway I can.
You made my day!!!!!
The Lunkster.
Lunkster
best regard
The best approach to build this motor and have success with it is to build the prototype with some adjustability into it.  Then optimization can be gained with it.
The drawing is close to the prototype I started to build.  I was building one out of larger pieces of plywood.  I left the wood with the magnets cemented into them in the garage over winter.  The boards warped and I put them into a fire pit and the magnets lost their magnetism.  That was because at the time, we started living in our RV full time and I did not have room for them in the RV.
I hope this will help you build a prototype.
Again thank you for the interest in building one.
If I can help you in any other way, please let me know.
The Lunkster
lota
Hello
Interesting. The rotor has no elktro magnets. Why the contacts? Is it possible to use square magnets? I would be able to build that. How many windings would the electromagnets have. The book would also intrilate me.
Greeting
Lota
