Ultrasonic / mechanical cavitation used to transmute matter
Started by ChileanOne, September 20, 2020, 12:56:32 PM
ChileanOne
You are again "cherry picking" the research papers, you have not adressed, at all, the most important results, those of the transmutation of Mercury.
I am very aware of the controversy that Cardone and others have faced.
The thorium decay was adressed by Cardone in several manners, but they have published recently three papers on the reduction of radiocativity of Ni63.
You insist in finding the evidence that supports your biased assertion that there's no way that Cardone et al might have found something real, you prefer to discredit their characters and cherry pick the results that have stirred the most controversy, but you say absolutely nothing about the VERY STRONG published results of their experiments in Mercury.
That says much more about your motivations than about their research.
ChileanOne
You are also, in passing, trying to smudge Talerkhayan, who has been relatively recently (2019), vindicated.
stivep
RESPONSE#9
Quote from: ChileanOne on September 23, 2020, 06:25:34 PM
No my friend .
I'm not against any revelations,  and definitelly not against Prof. Cardone
You not reading  what I wrote:
RESPONSE#3
Purpose of this debate  is not to prove anyone wrong but to  take all
possible sources to create in a mind of the reader  credible or  at least
clear picture of reality seen from a science perspective:
https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/msg550955/#msg550955
Please provide  your own  answer/ opinion  - to  the doubts and criticism of the cited papers proving them wrong, mutually opposed or inconsistent ( contradictory) or invalid.
Wesley
synchro1
Quote from: synchro1 on September 21, 2020, 05:47:55 AM
I believe the copper wire in my Spiral Quadfilar Toroid coil transmuted to selenium. The coil was Radio Shack speaker wire; All copper. After repeated very high speed Neo magnet sphere run ups, the wire turned dull silver in color and tougher to bend, more brittle. I really believe the quantum magnetic forces that caused the magnet sphere to actually gain several grams in weight while spinning, caused a transmutation of the copper metal wire!
I should have measured the weight of the coil before and after the run up. The coil probably gained weight along with the Neo magnet! Electrons were probably added to the copper's atomic shell. I can still compare the weights but it's obvious the metal is completely different just from sight and touch!
This process could be potentially catastrophic for the International commodities market. I believe different frequencies and materials may possibly transmute baser metal wire to gold or platinum.
synchro1
I am recovering the coil from storage for melting point testing. The relativistic theory used tp explain the weight gain can more easily explain the apparent change in metal, from lighter to heavier element.
I plan to tweet Jeffery Bezos if scientific testing confirms the element transmutaion. I was part of G.K. O'Neil's Princeton group and share Jeff's vision.
Ultimately a materials construction technology may include seamless element transition 3d printing.
