AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
nix85
Quote from: citfta on October 09, 2020, 11:44:43 AM
That is just not true.  I tried the same set up with several different loads and the current and voltage were always in phase.  Now YOU show us something that proves us wrong.
Carroll
Which means you got too much resistance and capacitance in the circuit and you have proved nothing. Also you used way too low speed, inductive reactance is XL= 2πfL.
Let's bring in someone whom you deem an authority as proposed, let's hear his opinion if current lags voltage in purely inductive circuit when induction is done by moving magnet.
How bout Thane Heins, is he a member here?
NdaClouDzzz
Quote from: citfta on October 09, 2020, 10:58:40 AM
So what happens when a magnet is moving past a coil?  The coil will have a voltage induced into it whether there is a load connected to the coil or not. This can easily be seen by just connecting a scope to the open leads of a coil and seeing the voltage on the scope...
Question: Does the scope not represent at least a little bit of load on the coil, and wouldn't using a separate sensing coil similar to that used in the following video be a more accurate test? https://youtu.be/hw2bBYYHp34?t=89
Thank you.
citfta
Hi NDZ,
That is a valid question.  But the input impendence of a modern scope is typically several megohms.  And I was using the 10x position on the probe.  So any loading of the coil by the scope is so small as to be almost unmeasurable.
Carroll
NdaClouDzzz
Quote from: citfta on October 09, 2020, 12:11:43 PM
Hi NDZ,
Carroll
Thank you.
citfta
Quote from: nix85 on October 09, 2020, 11:54:39 AM
You are the one making the claim.  I asked you to back up your claim and now you want someone else to bail you out.  Show us the proof you are correct!
