Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 41 Guests are viewing this topic.
mrl
Quote from: giantkiller on January 23, 2007, 02:58:04 PM
Ordered 6 samples of h11d1 opto isolators from Fairchild Direct. 2nd day UPS. $0.00 total cost.
Order some fast FET drivers too.  That's important.  Your rise and fall times need to be as fast as possible.
giantkiller
Way ahead of ya there bud! They were free too! Fets and drivers! ;D
Next I get bridge and 3055s.
--giantkiller. 8)
mrl
Ok -- I've just visited John's site and looked at one of his schematics.  From what I can see it's the same configuration for the SCR.  I'm starting to think that it will work as wired, in that we don't fully understand what is going on within the circuit re the dynamics.
John's not stupid.  Either he has published a faulty drawing or we don't understand it.  The only way I can see the SCR turning off is if there is a pulse from the coil system that is large enough to overcome the forward bias caused by the batteries.  I'm still thinking on it, but that's what seems to be going on.
Here's the site. http://www.icehouse.net/john34/bedinibearden.html
here's the charger motor.  See attached.
mrl
Quote from: giantkiller on January 23, 2007, 08:33:39 PM
--giantkiller. 8)
What are you using the 3055s for, if you don't mind my asking?
giantkiller
Quote from: mrl on January 23, 2007, 08:37:37 PM
--giantkiller. 8)
That is the power transistor 2n3055. I will have back up parts for other test. I snag samples whenever I can.
And I got that schem too.
Do you think that Bedini would blow smoke after all he's been up to at this point to falsify?
He has done too much. About the solid state ckt. Is a coil not needed? Fatbird said the inverer to the coil. So there are 2 trains of thought. I got options. Because with an inverter to the opto and radiant on the other side then this ain't tough at all. But that sounds like alot of shortcuts. ???
--giantkiller.
