Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bolt
Marco your very close and if you want to know why this happens especially at 7.5Hz then take a look at tesla work and how phases interact.  You see from the observers point we currently see the earth mag wave as very weak and is only enough to slowly pull a compass round and thats because when you have take a measurement you can only see the difference of a signal and not the real sides which are immense. Your motor setup was crude but non the less the interaction with this energy is enough to keep is running at that spot frequency when the phase is correct yet your not even attempting to harness this energy in a way the tpu is working.
Grumpy
in 1916 Tesla indeed spoke about a true electro-acoustic audio transducer that was part of a wireless receiver.
Quote. . Whenever I received the effects of a transmitter, one of the most convenient and simplest ways [to detect them] was to apply a magnetic field to currents generated in a conductor, and when I did so, the low frequency gave audible notes.
One of the simplest devices I used in my experiments between my laboratory on South Fifth Avenue and [at] the Gerlach Hotel, and other places in and outside the city, was an instrument constructed in 1896 with a magnet which sometimes was so designed as to give me a very intense magnetic field up to 20,000 lines per square centimeter. In this [field] I placed a conductor, a wire or a coil, and then I would get a note which I amplified and intensified in many ways. From the characteristics of the audible note, I would immediately judge the quality of my apparatus.
When I speak of an audible note, I mean a note audible in a telephone as produced by the diaphragm of a telephone, or by a vibrating wire within the range of audibility. . . . I usually would transform the current in the receiving circuit and make as close a connection as possible and then tune the circuit to the vibrations. I would also mechanically tune the wire, according to the frequency, to the same note or to a fundamental. . . . You could hear it all over the place. . . . I could hear it from a distance. The vibrations were very vigorous. . . .
[Nikola Tesla On His Work With Alternating Currents]
        -Frank Edwards
bolt
Think about how much is on tap when you create a disturbance to the near equilibrium that currently exist because we are actually getting close to about a 40,000 year cycle and reaching 0 point on the earth wave.  Does zero point of your AC mains there is no power? No its a measurement effect because thats only what you see at that point in time. If you disturb the flux by offsetting  the component that provides equilibrium then you can then measure and use the power.
turbo
well it works verry similair to a simple combustion engine.
and i am refering to the ignition like we had in the "mechanical" days.
these days we have electronic ignition with a sensor and a small magnet placed on the flywheel, but in the early days we had a "contact point" on a plate which we could adjust by loosening screws and rotating the plate to set the spark on time.
with this mechanism it was possible to set the parameters of maximum acceleration and or top speed of the engine, it was a timing thing.
the stepping motor acts in a similair way, meaning i have to fire a pulse exactly at the top of when it's position is at maximum magnetic compression.
if the timing is right and the pulse is strong enough it will accelerate to a point where it "hit's itself on the tail" so to speak and i can imagine this is what causes the vibration.
if i do this at 7.8 Hertz the motor keeps rotating like if the magnetic wave fills up the other "holes" or "phases"
i have seen it in various motors so it is not related to a certain model.
also some of the old floppy drives used a phased system with hall sensors and a crystal clock running at 650Khz.
these were also 3 wires and wrapped in multiple segments so it is possible to create a rotating magnetic field with more then one moving pole at the same time, and these were also wrapped in a way the "north" flux was always rotating at the outside of the coils and the "south" flux was being kept inside.
Marco.
bolt
Thats right so now think about the tpu. We want to capture this 7,8 Hz wave and we know its strong under the right circimstances and is much stronger then what you can normally see in a compass because despite our tpu coil or the motor winding being 100,000 times smaller than the earth wave the effects are very real.  So you just said yourself you fed the motor with 7.8 Hz and you see the effect. Now then, how do we make 7.8 Hz in our tpu??  Because when you do this you will see the effect. :)
