Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 18 Guests are viewing this topic.
giantkiller
Putting the 3rd freq in is Sooooooooo obvious now. I will build the 3rd freq gen and put it into another Bose channel. It will cause no damage to the Bose because the impact will be at a radial distance and not the center! OMG! And that is why the center works. Simply elegant.
The fun is getting better.
--giantkiller.
innovation_station
almost done here is the pic just have to wire up the controls
is
tell me if it is wrong so i know anyone??
giantkiller
Quote from: innovation_station on September 17, 2007, 12:26:06 AM
is
Very impressive. Apply the sine waves and lets see what you got going there. In the first attempt the balun is the pickup. The object is to drive the resonant fields to meet at the center. The compression will give higher power value. That is one way to do it. You should try to drive it from the center and see what appears on the outer ring.
Be careful.
--giantkiller. I just love what you've done with those cable ties.
innovation_station
cable ties quick n dirty  i love it
well i guess i need a diode on the input from my amped  3 freqs  well maby even 2 diodes both going the same way and we need to bleed off the cap with a resistor back into the input no? and some oput put leads   ;D
since my collector wire was 13'1" i know its freq is 7.5 right so 2  freqs left and some more wireing
hummmm....  tomorrow ;)
ist
bolt
IS nice looking coil i think your cap is much too big use 0.1uf film cap or poly non polarized its hanging on the collector loop and will be subjected to extreme stresses and electrolytic may explode.
GK excellent work i think your doing the things about purity to understand how this works that SM suggested over a year ago.
Grumpy stop being so grumpy. If you think it needs one 2 or 3 then do it on your design but im telling you in MY opinion ONE collector ONE balun to mix. Incidentally until such time there is the correct feedback loop done on the TPU i see the risk as low because it cant run out of control with the sine power going in. However the effects of the forced feeding should still be seen. Not to say even this testing could suddenly give such a massive kick you will know!
Once this is looped around the ballun and fed back to the input then and only then does this turn into a serious hazard but in any all cases collector fuses are the absolute minimal to prevent the entire thing suddenly shrinking then pouring with smoke and flames before you even get chance to lean over and turn off the PSU.
