Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
starcruiser
Well I just tried out my theory on a small scale and I got some promising results. The exciter circuit works as expected.
Unfortunately the 12v battery is just about dead less than 11.6v) and the TPU's lower control coils has a short in it. The resistance of the upper layer on the TPU is 9.5 ohms and the lower is about 6 ohms so this means I cannot generate a stable field.  This short is most likely due to the HV experiements I was doing on my last tests. I guess 30KV cooked something.
Well to the results....the exciter/Osc circuit was providing about 5vpp signal into the series connected control coils and the secondary was providing approx 2.2vpp. (see scope shot).
I then used a single diode to see if I could rectify the signal and was able to obtain a little over 1vdc with a ripple on it. (see second scope shot)
These results are without a magnet to "tickle" or "excite" the windings.
I am thinking that if the following items are addressed I can improve the output;
1. charge the battery to full capacity
2. re-wind the control coils to provide a larger field (more turns of 30ga magnet wire)
3. make sure the control coil(s) has a resistance of at least 60 ohms
4. use a neo magnet to excite the feedback process.
I know some will say this is nothing but a simple transofrmer action, but I say "I know this is a fact". I feel that if I increase the field from the coils I can start the electron avalanche I am seeking.
This is just the first stage in my testing and was a proof of concept and that more can be achieved with the correct setup. As a result I must now start winding the new TPU with the improved coils.
Regards,
Carl
giantkiller
Quote from: FatBird on March 01, 2007, 07:47:34 PM
Question for group.
When SM spoke of a Rotating Field, did he mean:
1.  Rotating Back & Forth like a washing machine agitator?
OR
2.  Continuously rotating like water going down a drain?
Each one has its own circuit implications.
Thank you.
To reiterate additively:
One way for Option #1 is the bucking field 390721 patent in 3 layers using Otto's jumpers. That is post #2 in this thread.
One way for option #2 is Moabs
http://www.overunity.com/index.php/topic,1872.msg22653.html#msg22653
Somehwere around there. He even posted the sequence diagram.
But we both got kicks. Oh, please! Is this old news or what? ;D Doesn't that sound great?
--giantkiller.
giantkiller
@starcruiser,
I was in the lab with someone and in a discussion about Radiant Energy. If that energy can go through anything then anything can become a short. We talked about keeping everything out of the center space of the ring so the field would have no interference or place to go to as the center field commences, condences, & compresses. Just a thought.
The materials we are using are for a lower level of energy, current. Current can't travel that far through air. Radiant E can go forever. One of Tesla's speeches.
What do you call a TPU pulsed by a stungun? Frankenbuzzer. :D
--giantkiller.
Sauron
"Also, there is another interesting analogy.
We seem to overlook so many things in our society.
They are right in our faces but we just look around them without interest at all."
