Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 23 Guests are viewing this topic.
Jdo300
Also, for the transistors... well. first of all. Don't use transistors, use MOSFETS. They don't need significant current to switch on (in the nanoamps). and as for the type you need. You want a MOSFET with the lowest gate capacitance. What this means is that the MOSFET will switch on faster when the required voltage is applied to it. The gate is essentially a capacitor, and we know that small caps charge up faster than large ones. This is the only factor that will determine how fast the MOSFET can switch on and off. Theoretically, a MOSFET has infinite rise time if you could charge it up with an infinite voltage spike. So the MOSFETs are as close to a switch as we will get as far as I understand. Also, get something that can handle at least 100V at 1A. They are cheap and readily available at RadioShack for about $2.00 each.
God Bless,
Jason O
innovation_station
giantkiller
Quote from: innovation_station on March 27, 2007, 04:39:03 PM
Quote from: FreeEnergy on March 27, 2007, 04:14:22 PM
Quote from: innovation_station on March 27, 2007, 04:06:30 PM
the pics of the test i did last night as i said i would post
is
how are you hooking those wires up exactly?
i hooked up the wires like this
the steel welding wire to the volt meter  only 1 end the other end i touched
the speeker wire was wound bifolar and connected togather at 1 end and i touched the other i touched with my finger  and the last wire was to the volt meter so there was no connection between the steel wire and the speeker wire some how the small voltage from me went from steel to copper without any connection between
strange but it worked as you can see in the pic
is
Nice proof. And you were going to leave? I think not after this. You are now a permanent resident.
Welcome to the fray.
--giantkiller.
innovation_station
