Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 20 Guests are viewing this topic.
Bruce_TPU
Great post!  Great detail Gk!  Good looking setup.
It is good to know that someone else's bench looks like ours did!   ;D
Warm regards,
Bruce
giantkiller
Does anybody see how close the last PCV coil rendition is applicable to Tao's instructions. It is a beautiful mix of operational TPU instructions from the past.
All radiant energy related.
1: the pcv bobbin like windings go all the way around the collector.
2: the top and bottom of the pcv bobbins act like the ECD 6" wing edge.
3: the loose 45dregree on the Helmholtz's winding acts like the ECD 4" wing edge.
4: the Helmholtz's manipulate the middle collectors field if needed to try.
5: I even have a second middle collector that equates to many fine wires of the EZflow audio cable.
The GK4 is similar to the layered version that Tao shows. Even though he shows the layers as steps.
Not bragging. I am glad I built the number of coils I did. I have plenty of platforms to work from. Though I would like to wind another one. ;)
I have alot of tests to do when I get rid of the fet noise in my circuit.
--giantkiller.
weri812
hi gk
on  your  crown of coils
the virtical wires in the notches  try puting at a 45 degreese in stead of  up and down
like this  \\\\\\\  not this  lllllllll could that help in making the field rotate with max transfur of energy ?
just asking
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
joe dirt
Well...I decided to join the three frequency club, but, as Murphy would have
  it, my power supplies are toast... ha,hahaha,ha :'(
giantkiller
So I finished building 1 of the 4 small footprint fet boards with matching Max621 fet driver. I will divide that board in half.
The top board is the old fet mount in the picture.
While the signal is really clean and sharp, I now have a heat problem at 100ma for only the one fet installed to the coil. This is fun? I thought I got rid of the heat in the previous board?
I think my intelligence is but a transport mechanism for aggravation.
Why doesn't this level of effort qualify as suicidal?
So this step will facilitate the fet placement inside the coil. I has occurred to me that when the ramp-up to the fully operational point is achieved, a quiesence level is attained due to the magnetic field operating at a certain speed based on the frequency of the resonance. This creates a dampening effect on any ringing or extraneous oscillations in the solid state devices. Like saturation of an iron core transformer. Though we are using the external magnetic level instead of eddy current resistive level. Once again the coil does the work virtually... ;)
The ramp-up is but the transistion from a noisy to a smooth operation. Just like putting the microphone closer to the speaker.
@Joe Dirt,
Come on, you know you can't leave. The enjoyment is just beginning. Huh? When did it start? Only the builders can claim fame here. We got scars.
--giantkiller. I will conquer at all costs. Including myself... Cooked, fried, blown up, its all the same. Damn coils!
p.s. In the words of John Lennon: 'Life is what happens when we are planning other things'. But in the words of the Universal Geek Master: 'No life! I'm obsessed with technology! Now leave me alone I have stuff to create!'. No wonder God is a full time job. He must be a geek too.
