Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 17 Guests are viewing this topic.
giantkiller
Gentlemen,
I can do both. The easiest and fastest way is baby oil or cooking oil and laser toner glued in a clear plastic box purchased from hobby store.
Jason also mentioned a class of water with salt dissolved in it to see the vibratory and rotational aspects of the fields. I then add black pepper to mimic the iron filings movement.
I will find iron filings also. If I can't buy enough of them I can go to a metal shop and get some cut. I have 10 pounds of iron pipe section from when I started this last year. The dollar store probably has those cheap magnet drawing games too. I will buy bunch and have multiple tools in different places of the field.
I have clamp on ampmeter also. But that is like using only your nose at the race track. Some much goes by.
I was involved in one of Moab's TPU tests and I suggested he put a glass of water on the middle. He reported that the surface showed ripples of fields moving.
--giantkiller. TPU plug -n- play. Oops, Microsoft might try and write decrepit drivers to incorporate it into windows. Then we would need updates everytime we turn it on.
bolt
Im sat here thinking about the SSG, there are answers in there too.  Its proof RE is real otherwise these things wouldn't work and i seen plenty that run on their own. I remember reading somewhere the trick is to minimize conventional electron flow. In SSG as soon as the magnets produce the pulse the conventional input circuit is slammed shut and the resulting wave is captured in a circuit which defies normal electronics. In these simplest designs the SSG requires some help to get the thing going but that entails a huge waste of inertia, friction and mechanical movement yet RE can cover this in slightly more complex systems an still charge a battery. For TPU we dont have these losses. Even a crude design may only need a tiny help to get the thing running via a PP3 9 volt battery and this input can be covered later once the TPU starts making RE. Its interesting how SM still requires magnets to start the TPU.  Need to try and replicate the effect of a magnet moving pass a coil and capture the resulting RE in the bifliar trap with zero electron flow.
Well i guess im going to have to find my old soldering iron very soon:) In the meantime read some more posts in this thread. .....heavy stuff indeed.
innovation_station
i agree on the iron fielings  put in a glass wine bottle fill with cooking oil and fileings put inside the ring you can then see the magfeild in a 3d enviroment
ist
giantkiller
Of all the intricacies and areas of the TPU operation it is interesting to see where people latch onto. Earl has been on this part for months about using zero current.
--giantkiller.
bolt
In one of the vids SM demonstrates the larger 800 volt system. When he turns it on you hear him clearly say. "turning on the 1st frequency and now turning on the 2nd frequency and now the device is now running"  which appears to be done using two separate switches. So there may not be a third frequency unless of course he just doesn't want us to know that but then why start the system flicking 2 switches.Why not 3 or 1. Again in that video he remarks the unit is producing DC but later lets slip its 5000 Hz. Another vid he said they are producing 6k Hz.  Whatever i would bet 5 or 6khz is a good starting point but also the variation between vids remarking on the output Hz indicates this frequncy is NOT critical not as if its tuned into the earths clock or anything like that:)  It doesn't appear to me this frequency is like 5.55675khz unless he is rounding this up and down to 5 or 6.  From 2 frequency we know we can produce harmonics, constructive and destructive waves depending on phase etc and other frequencies from 2 clocks. What would produce the 7.5 Hz that can be felt? This is interesting maybe its the flip flop circuit seen in  the RE hydrogen split which we have seen is a slow pulse 3 Hz  modulated with HF running at about 16Khz. Maybe the 7.5 Hz could be the DIFFERENCE between two 5kz clocks. In the hydro split only 2 frequencies are used.  The SSG can be described as 2 frequencies also. The wheel turning is one frequency and the magnets passing over the coils is the second frequency.
Does anyone have any really good close up photos of these devices? The more we can learn from then the better.
