Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
kames
Hi Bolt,
I cannot agree more except for one thing, a kick. From ?the horses mouth":
??.But if you make enough of them FAST SENDOFF, you get a collectible power spike that is more then the power available to begin with??
Kames.
giantkiller
Hence, pumping the echoes with a slight push to 'send' them in sync outward.
--giantkiller. Cannon balls. Not down the wire but outward into space. Thump, thump, thump, thump... OMG!
giantkiller
I will skip the 3 segments setup and leave the control as 1 segment and drive in 3 freq just like the ECD.
Sm used tubes to experience the functionality of fidelty first. Then went to solid state for simplicity and scale.
But using 2 freqs will produce a 3rd in the phase cancellation that is very high speed. I wonder if he meant radiant energy as the 3rd? I have always wondered that. Especially if he purposefully addressed laymen.
--giantkiller.
bolt
Gotta work out the harmonic solution for the 3rd frequency.  Then you only have 2 to find. Its all part of the jigsaw:) It still doesn't look like critical spot frequencies are required more of finding the LC type of sweet spots to the system so that each control coil fires ahead of then next one so the mag forces kinda of spins around the coil creating massive internal forces and gravitational effects. This is akin to SSG wheel spinning about 120,000 RPM:) SM calls this the turbine effect.
Anway i recon we will have this sorted by next Tuesday then we can look at anti gravitational devices and flux capacitors the week after. HAHA!
Giantkiller please point me to your latest posted design see if i can spot anything.
bolt
i haven't followed every post but SM has given very accurate description of the coils. He said he cant talk about the control circuit as its hushed under patent....no worries we understand.
This needs to be reproduced as faithfully as possible it must hold the key
1 There need to be three of them all the way around.
2 Start them up one at a time each.
3 First frequency then SECOND HARMONIC COMPONENT into the second, then the third.
