Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Grumpy
Time to hack through some more of the BS jungle...
With a magnetic vortex and method implied above, the amount of energy that would be collected is related to the rotation speed of the vortex (i.e. the rate of change of the field) and the field strength - just like any magnetic field.
Next is to take a solenoid coil around a lamp wire and sweep for the frequency that produces a response in the DC-biased lamp cord or find the longitudinal resonance freq and work from that.  Like Mark Snoswell and Eric Dollard have both mentioned, you would not find the LW freq without looking for it.  Talked to a guy that is heavy into Tesla wireless transmission about a week ago and he pointed out that Tesla's pancake coils have a wide LW Q - making it easier to find/tune.
Pretty neat concept, really.
Controls in center of TPU, since rotating field will shield them from outside and eye of TPU will be nice and quiet.  I would expect an element of cycloidal rotation once it gets up to speed - so the inside will flow opposite the outside - like a mobius simulates - look at the flow directions - inside is opposite the outside.   I've mentioned most of this before, just not in one place.
Kudos to Mark Snoswell for his LW experiments.
Get busy, winter is coming!  Now where did I put that ammeter?
EDIT:
It is rotating at about 70,000 RPM - way faster than 7.5, so forget the damn Schumann Resonance - it was only an analogy!!!
        -Frank Edwards
innovation_station
hummmm... high speed eh!!!
to lay this down our pancake coil should be 13'1"or3.99m or just under it is a loop ant like a fm reciever wire open ended? the lenth is critical for the 7.5 longatudal resonance of the "collector" and it should be able to carry upto 100 amps at 1 volt  or can some one brake this down more
cuz our collector can be shorter but heaver gage
is
bolt
6000 hz hash is the number of times 1 coil winding has been cut by the rotating flux. Now i have 800 turns on my output coil so
6000 / 800 =7.5:) = 7.5 * 60 = 450 RPM. Is this too slow? Nope my collector is producing 800 * 1 amp = 800 watts / 800 amps at 1 volts * number of turns in collector say 10 turns = 80 amps per turn with only 0.1 volts.
A power station is only cranking the handle at  50 or 60 Hz yet makes mega watts.
bolt
The amount of current collected in the collector is huge with little PD. Really the TPU needs a super conductor because as soon as its scaled up the amount of heat becomes uncontrollable due to the resistance in the wire.
innovation_station
wow!
bolt did i ever just find you all the sloution
lol!!
white powder gold ;)
no heat or verry little ........no wories     :)                          how much can you pull now??               from a 6" tpu
bolt agreed we must first see it work b4 we can then fix it
but i can not help it my mind races fast and should not be slowed down!! that only confuses me as i still am  confused on the operation of the tpu but that is ok
i look forward
william
